Tire pressure: BFG K02 ‘18 Tacoma w/ Fleet flatbed camper
Fleet007
Oct 15, 2018
4
Park City, UT
Hi, looking for a little advice. I reached out to BF good rich and they were adamant that they cannot recommend any PSI other than 39. I’m running a 2018 Tacoma with a converted flatbed, carrying a 2018 4Wheel Camper fleet flatbed model. I purchased the camper fully loaded. My BFG K02’s are 265/17R16 with an E load rating. I know this topic has been discussed before on here but never specifically with the Tacoma and flatbed camper so I’m hoping to get some suggestions from you guys. What tire pressure do you think I should run on pavement, and then perhaps on backcountry roads? Thanks very much in advance. Mike.
Here's a couple of comments on this topic from some earlier threads. I checked into this with Toyota a few years ago.
Copied from: http://www.wanderthewest.com/forum/topic/14042-10-ply-tire-pressure/
"I posted about this earlier in this thread: http://www.wanderthe...d-air-pressure/
Toyota gave me some new door stickers for running LT tires on the Tacoma. - 46 psi front and rear for LT265-70-16. There was a Toyota TSB about this some time ago but I have lost the link. The dealer will install the new labels if you ask them. Saves having to redo the pressures every time you get the truck serviced."
Here's my take on tire pressures with our Fleet on the Tacoma.
Starting with the original tires from Toyota:
Toyota's placard pressures for the P rated tires are 30psi, front and back. The empty weight of our truck, fully fueled with two people (we weight 160 and 120 lbs) was 2700 lb front, 2000 lb rear.
Max axle weight per placard are 2910 lb front, 3280 rear.
So why does Toyota recommend 30 psi for all four tires? No idea, but a couple ideas are they are trying to keep it simple, optimize for gas mileage, braking performance, traction, etc. Let's say the truck is loaded with 800 lb over the rear wheels and the passengers weigh 100 lb more than we do. Then both axles have 2800 lbs. This makes my thinking easier. It seems like a typical scenario that Toyota's engineers may have assumed.
The Kevlar tires that came on the 2018 truck are rated for speed T, 112 load index which is 2469 lbs/tire at 35 psi, max 51 psi. There are no table values past 35 psi. For trucks, P rated tires are to be derated 10%. Per https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf (apparently Toyo tires are sized a little differently, so I did a little interpolation) the tires are rated at 30 psi for 2275 lb each tire.
Derating by 10% reduces this to 2068 lb/tire.
So if we load the truck to 2800 lb/axle, and have the capacity of 2 times 2068 lb/tire, then the tires have a "safety factor" of (2*2048)/2800 = 146%.
Overloading the truck and using E rated tires:
So then we got a camper, loaded it with water and camping junk, etc. and our axle weights went to:
2800 lbs front, 3600 lbs rear. Front is ok (max axle capacity 2910 lbs), rear overloaded (max axle capacity is 3280 lbs). We added Sumosprings which leveled out the truck and it seems to work well on and off pavement. We bought BFG KO2 tires, E rated which have tougher/more plies, and should use higher pressures.
I never found out why E rated tires need higher pressures. Perhaps the more plies create more heat. I've read that heat really damages tires, so under pressurizing is bad news.
After reading the toyo tires link above, it appears the basic method for E rated tires is to keep a similar safety factor. So I ran these numbers for the E rated tires in the same document, derating by the 146% factor. Their method is worded differently, where they ask you to use the rating at a certain load, but I think it amounts to the same thing. Maybe I'm interpreting this wrong, but it seems to match other methods I've seen mentioned*.
So I took the line for the LT265/70R16 Single tires, multiply by two tires per axle and divide the capacity by 146% for the same safety factor, and get this:
psi 35 40 45 50 55 60 65 70 75 80 Wheel weight (lb) 1,820 2,000 2,170 2,335 2,500 2,655 2,835 2,955 3,105 3,195 Axle weight (lb) 3,640 4,000 4,340 4,670 5,000 5,310 5,670 5,910 6,210 6,390 146% 2,267 2,491 2,702 2,908 3,113 3,306 3,531 3,680 3,867 3,979
So I weigh the axles and pressurize according to this chart. For mine it's 45 psi front, 65 psi rear. The 65 seems too high, so getting emotional about it and worrying about too harsh a ride, I use 45/55! That's the illogical conclusion. But I've only been on one long trip so far and will try the higher pressures next trip. Off pavement, very rough roads we've had success with 15 front /20 rear psi.
By the way, your flatbed with extra water, etc probably weighs more than ours. We've removed some stuff to lighten the load too, like the bed extender, not-full tanks most of the time, and lightweight backpacking gear.
*Other methods include:
http://www.fourwheeler.com/how-to/wheels-tires/1801-the-pressure-where-should-you-run-your-tires/
and lots of anecdotal ramblings you find all over on line that are not scientifically based. One was from a tire dealer that made absolutely no sense! Lots of people on line say "I've always done such and such, and it's the only way to go", but I didn't find the reasoning very compelling.
A fair amount of intuition would be required for the following: Perhaps having a close up video of at least one front and one rear tire during varying travel conditions would help evaluate the sidewall at the point of contact?
Did Toyota determine the 46 psi or did you tell them to put that on the sticker?
Most E Rated tires have a max of around 80 psi.
I use to run my E Rated tires around 50 front -- 55 rear.
(when loaded up & ready to go)
Just my personal experience.
Toyota determined the 46 psi. Most Tacomas have P-rated tires from the factory but some were delivered with LT tires. The pressures on the OEM door stickers were too low for the LT tires. As a result, Toyota issued a TSB regarding running LT tires on the Tacoma. They issued the new stickers to conform to the TSB for those trucks supplied with LT tires. While my truck was not supplied from the factory with LT tires, the dealer was willing to put the new stickers on my truck since I had put LT tires on it.
I have been running the recommended pressures with good results. I got over 60,000 miles on my first set of BFG KOs. I'm now running KO2s.
takesiteasy said:
... While my truck was not supplied from the factory with LT tires, the dealer was willing to put the new stickers on my truck since I had put LT tires on it.
Thanks. I am in the same situation, so will ask the dealer. I have Cooper AT3 E with 30K on them and looks like they will go to 70k. I have been running 44 rear, 40 front and am slightly under GVWR when fully loaded, but I have the shell Fleet so no propane, water tank, etc.
Is that with a camper, or an empty truck?
By the way, the 46psi for E rated tires corresponds well with the 30 psi for P rated tires, using the method in the Toyo link above. Since we tend to overload the rear, more pressure for the rear tires seems like the right plan.
Our camper is on the truck about half the year (stored during the winter). Most of the miles are on pavement with the camper on the truck. I don't drive the truck much during the winter.
Does anyone know how I start a new thread on a new topic? I've tried everything but the only option I get is to send a private message to up to 5 people.
Mike
Mike
Mike, click on the specific forum you want to post in, example “Trip Reports”. You’ll then see a rectangular button for “Start New Topic”.
Lot of good information, I’ve settled into the same of about 45psi front and 55psi rear with ko2s on my Tacoma with an ATC bobcat. Lower psi to about 40psi all the way around with no camper.
My 2 cents:
Our 2013 Tacoma weighs 4400 pounds empty (no tailgate, half tank of fuel, no driver). 2012 Eagle (improved) shell weighs 1,100 pounds empty . Camper loaded permanently. We run Hankook 10 ply LT265x75R16 on the street with camper empty (of portable camping gear) we run 36 pounds front and rear. For washboard roads 28-30 psi for comfort.
After 60,000 miles tires are wearing evenly... Driving 2-3 days per week. Truck sits in the shade when parked.
Comment from "rubber legs" about changing out the door sticker.
One of my "knowledgeable" engineer friends said that doing that may effect the annual registration fee if Toyota reports the change to the DMV. As the vehicle weight is the number the DMV (California) uses to set the fee.
I have NOT verified this out with Toyota - Yet !!
The new door sticker does not change the vehicle weight rating. It only changes the recommended tire pressures for LT tires.
Having just discovered this thread I am late to the party. We have a 2019 Tacoma with a fleet flatbed and a norweld tray, it weighs 6500 pounds empty. We’re running 275/70/17 BFG KO2 tires, load range E at 50 psi. We plan on airing down by 1/3rds; 34 psi for gravel roads and 17 psi for sand.
