To Boat Rack or Not to Boat Rack?
ArtTrek
Oct 24, 2018
24
We're picking up our 7' CO at the factory in June... Still pondering, and need to call Bryan tomorrow, whether or not to add the optional boat rack. We have two light weight kayaks, one of which I use for fly fishing in lakes.
What is your experience? I'm tempted because we have a beautiful lake campground up in the mountains, just under one hour from home? I probably wouldn't do long distance trips with the kayaks on top, because of wind resistance, but am definitely thinking about it for a shorter trip...
Would appreciate your wisdom.
I'd go with the boat racks as you never know when they might come in handy and installing them now is easy for Bryan to do. I picked up our 10ft Alaskan Cabover from Winlock last May and struggled with adding the boat racks. In our design we have an AC and 2 Zamp solar panels up there so most of the real estate is taken up. I too fly fish mountain lakes and have decided to use www.bucksbags.com (float tubes) to fish out of and will store them along with other items in a soon to be fabricated back porch. All the best....The Alaskan Camper folks are awesome to work with.
wagoneer said:
I have the rack on my 76 8' CO and I love it, can use it for solar panels as well.
How do you handle getting boats on an off? it's quite a ways up there... Do you bring a small ladder along? I'm not concerned about weight, because our kayaks are light, but wondering about access to make sure they're strapped down tightly.
I use my float tube as well, but am thinking about using the Kayak and then my wife and I will each have our boats...
Yes it is very high up on top of an Alaskan Camper and probably my boat racks are just extra bling and will serve no purpose but if I were to access them I'd use a telescopic ladder.
Other than the standard Alaskan factory equip I did the following changes:
1) Increased water tank to 34 gal by changing a few floor measurements
2) Placed 2 additional COMBO 12V/ USB chargers for total of 3...one under the step wing in the dinette area and another external under the refrigerator access panel.
3) Installed a PlatCat heater (http://www.ventedcatheater.com/heaters) which burns far less propane and electric than forced air units. I have both heaters in mine....the forced air warms things up real quick and then the placat takes over.
4) Installed a cell phone booster antenna on the real external wall (https://www.wilsonamplifiers.com) and a wifi booster antenna on the rear wall (https://www.radiolabs.com).
5) Installed a larger Novakool refrigerator (3.5) without a freezer
6) Beefed up the cabinet facings on the water tank wall and in front of the dinette to 3/4 in for the potential install of a Lagun table (https://www.lagunusa.com)
7) Used Progressive Insurance to insure the camper....they seemed to be the best overall at RV's & will insure for the full invoice amount.
8) Blackout curtains on all windows and door
9) Increased size of propane tank to 30 lbs.
10) LED lights at back porch and on side wall where awning is installed
11) Installed 2 Lifeline AGM batteries (210 amp hours each) from www.impactbattery.com to compliment the solar panels
If you have questions on the above just ask Bryan to look up my order....Lloyd Anderson//Seneca, South Carolina
All the best on your build....Lloyd
ArtTrec, I would vote on having the factory add the boat rack brackets.
I just purchased an '04 8' CO. It came with boat racks, that the second owner told me the original owner hauled a 13' boat on them.
The original owner sold the camper in 2017 when he was 82 years old. I'm not sure how he loaded and unloaded his boat, but after inspection of the top there were no dents or dings indicating it was difficult.
I removed the racks in order to cover the camper until I can be sure it's all sealed up good on top,
Removal was easy. Each bracket was held on with 2 studs, each 1/4" x 1".
If you were to not get the factory racks installed and decide to install them later yourself, I think putting the studs in could be a problem.
Good Luck on your decision. bcb
My Alaskan has the racks on it, probably from the factory. I think if you ever consider mounting anything up there, the factory install would be the way to go. You just don't want to start drilling holes and maybe cutting through the wiring or something in there! In addition to using them as boat racks, I think you might decide to rig up a canopy off to one side so having the racks to tie off to makes sense unless you are ordering a factory awning mounted on it.
Thanks for all the wisdom! I really appreciate the chance to put a topic out there and read everybody's perspectives. If I were going with a boat rack, I'd definitely go with a factory install. In the end, I've just decided to take along my float tube for fly fishing...
Later...
Art
I recently purchased a 8.5 CO and had 3 sets of the Yakima false gutter installed, they give me the option of 3 bars for a boat rack, basket or any of the Yakima accessories, yet the roof is free if I don't need them. Bryan prefers the false gutters to the track because it requires fewer holes in the roof to install. Good luck with the new camper!
you can see my boat rack in gallery pics on a 10' cabover. It comes in handy for all sorts of things including my rear awning support for rain cover. I too have a telescopic ladder for getting up there. If you launch a boat, you need a rubber padded T-BAR support that mounts to your rear trailer hitch so the boat has a pivot point to push against when parallel to the ground and getting lifted up 90 degrees.
here are pics
http://www.wanderthewest.com/forum/topic/3747-alaskan-camper-gallery/page-8
flyboykev
