Top blowing up in wind and water tank!
Oz_70
Aug 1, 2011
25
Kitsap Peninsula, WA
Two things. First, what’s up with this and what should I do!? I was going across the Tacoma Narrows Bridge during a spring wind storm when the top of my 8' Cab Over blew up about 5 inches in the front! I pulled over and it rested back down to normal. I then took off on the highway and made it half way through Gig Harbor when it happened again! I know I have a leaky back right hydraulic, so later I checked the reservoir and it was low, about a little less than 1/4 of a reservoir tank so I filled it up. (BTW, I found out it SHOULD be filled with aircraft non chemical MINERAL based hydraulic fluid....and it’s sold at the hardware and store and not automotive stores!)
Was the reservoir not being full causing this?
Should I install a hook and ring manual locking device in the front to secure the top?
I recently replaced all my o-rings, the hydraulic is not bent, so does anyone know why is it still leaking? Should I install a larger o-ring….and does anyone know what size is slightly larger than what Alaskan Campers sold me for replacement O-rings?
Second, and last, my water tank blew its seems. Does anyone have the size and an internet link to purchase a new one?
Thanks all! You guys rock!!
Oz
oz,
i have a tank out of my 10' nco(i think, it's been so long)and a spare tank that came out of another rig thats close to same size.you're welcome to one if you want it for free. can't say what shape the inside is.i'm sure they will need cleaned
the one that i think is alaskan is 8 1/2 x 29 1/2 x 13 1/2
the other one is 8x24x16
also, i tie my top down with ratchet straps in transport. works great
wes
Do you close the pump valve after you drop the roof?
Hi Wooddog, yes I close the valve, but it still comes up, which is why I was thinking maybe I did not have enough hydraulic fluid, maybe it was not completely a closed loop, if that even makes sense?
Oz
oz,
wes
Wes, thanks for the sizes. I will take mine out soon and measure it, but after filling the last tank up and having its seams seams blow out, spilling water all over the camper, or at least a gallon full before I managed to vice grip the tank together and drain the water, I am looking at a new one. I don't want to risk that drama again! But if I can't find a new one I will see if you still have yours! Hows the camping going?
Chris
Are you traveling with the front, upper vent window open?....or any windows open for that?
it has been known to create positive pressure enough to lift the top beyond the pirelli seal at which time the pressure is lost and it stabilizes....
sometimes a lack of pirelli seal will cause the same effect
I think this happened to Mike at one time...if I'm not mistaken
It sure as heck did! The only time I have had the top raise was when I was driving at freeway speed with the front window open. Certainly, having little or no resistance from your top and bottom seals will make it that much easier for the top to raise.
Mike
All windows where shut and it being a Cab Over I don't have a front window. Sure is puzzling. I am thinking about a hook and latch system on the front?
Oz
Oz
Being a cabover could explain how it came to raise if the wind got beneath it. I would definitely investigate the use of latches to secure the top. I believe there is a thread to that effect if you do a reverse search of posts.
Mike
Are your cab over pirelli seals all in place? I believe they were doubled on the cab-overs.
It could be that with the hydraulic problems you're having there may be a bit of air in the front cylinders. That would give them room to move....bleed the system and filler up
some windstorm....isn't that were the bridge came down in a 1950's windstorm?
I also use a ratchet strap in front of my NCO while driving, after having read in another forum about someone a few years ago losing the entire top while driving at highway speeds (from what I recall, they had not noticed it had come off until they stopped at some point, and the top was entirely gone). Scary.
I may also look at installing some kind of secure latch to prevent this from ever happening on mine. Better safe than sorry...
About driving with the front window open on NCO, I have read on one of my Alaskan instruction sheets that on dusty roads, it helps to drive with the front window open, since this "creates a positive pressure" which helps keep the dust out.
Cheers.
p.s. just read in the gallery the page from the manual about raising and lowering the camper, and one of the steps says to "release the travel lock" (before raising). I wonder what this "travel lock" refers to...
