Oz_70
Two things. First, what’s up with this and what should I do!? I was going across the Tacoma Narrows Bridge during a spring wind storm when the top of my 8' Cab Over blew up about 5 inches in the front! I pulled over and it rested back down to normal. I then took off on the highway and made it half way through Gig Harbor when it happened again! I know I have a leaky back right hydraulic, so later I checked the reservoir and it was low, about a little less than 1/4 of a reservoir tank so I filled it up. (BTW, I found out it SHOULD be filled with aircraft non chemical MINERAL based hydraulic fluid....and it’s sold at the hardware and store and not automotive stores!)
Was the reservoir not being full causing this?
Should I install a hook and ring manual locking device in the front to secure the top?
I recently replaced all my o-rings, the hydraulic is not bent, so does anyone know why is it still leaking? Should I install a larger o-ring….and does anyone know what size is slightly larger than what Alaskan Campers sold me for replacement O-rings?
Second, and last, my water tank blew its seems. Does anyone have the size and an internet link to purchase a new one?
Thanks all! You guys rock!!
Oz
Oz
