MANXMAN
I have a Tacoma I use as a run around daily driver and was thinking it would be the perfect truck to build a light weight solo camper onto for the trips when my wife can't came along. I'm retired so I spend a lot of time exploring on my own.
A NCO type FWC/ATC style pop-up should be light enough to easily stay under the payload capacity of a Tacoma and have enough room for one person.
The Uro-Camper Biwak is an incredible example but too expensive to import.
FWC made one called a Cajita for a little while. The one below belongs to fellow WTW member BurkeDroppings.
This little camper is the right size for a single person and could even be better in a flat deck style. A couple of sketches of floor plans showed that all needed luxuries can fit into it and the weight should end up around 700 lbs. Plenty payload left for me and a dog, and if kept to 75" wide will go anyplace a Tacoma can fit into.
Maybe Marty and Jeff at ATC would be interested in building one in a flatbed shell for me.
I read a few threads about these little NCOs here and there seems to be very few who think the idea makes any sense, but it sure interests me. What do you think about one of these for solo use. Positive or negative.
