scappoosebrad
Have searched many previous discussions about the use of inverters while under solar power only, but found no info about my question.
First of all, I struggle with many electrical discussions...that said, am looking for a few easy to understand, layman's responses to my question...
we were trying to charge a tablet and cellphone using the solar only system USB plugs(at 12.5 to 13.5 volt level)...to do so, we had to remove the 110v adapter to both of these devices, plug in the USB line directly to the campers "power board", and turn off the device...when done, it took 4 to 6 hours to recharge these devices--twice as long when charging at home using the 110v adapter to 110 power outlet...
My question is, if we used, say, a 300 volt, $30 inverter plugged into the 12v plug under solar power, will it reduce the charge time for these devices? Trying to decide to purchase one of these inverters if it will solve this problem...and I might add, we do not anticipate an inverter use on any other larger appliances, e.g. coffee grinder/laptop/etc. other than our cell phones, tablets, MP3 players, mini speakers...
thanks for your thoughts...
