UPDATE: For Sale (Package), $50k or FWC Eagle.
It will be cross posted in other forums, etc.
2015 Ram Ecodiesel with 2001 Eagle (completely rebuilt in 2015). I have logged every fill up since purchased (at 6k miles). Current mileage is about 53k.
This is a turn key setup. It will be for sale in about a week and I can post up to date pictures then.
If you need any documentation or have questions, let me know.
I'm in Boise, ID.
Truck Item
Outdoorsman 4x4, 3.0L diesel
Differentals, transfer case fluids changed Approx. 53k miles (may go up a little) HD springs on rear Airbags on rear New windshield Dashmat Updated maps in 2019 Full Seat covers (front and back) Weathertech floor mats (front and rear) Heavy/thick guage wiring to camper 6awg? Heavy duty step into camper Added full skid plates Extended warranty until 7/1/22 (transferrable) 20" OEM wheels w/ Michelin LTX M/S including full size spare with same tire (steel rim) Block heater with external plug mounted under front fascia All recalls, ECM updates, etc. are done Every tank fill up, maintence log, etc. since 6K when purchased Have tailgate w/ camera (extra OEM camera installed on camper platform) All Oil, filters, etc. just changed
Camper
Replaced furnace board *** New items were done in 2015 New vinyl (2015) New push boards (2015) Jack brackets (no jacks) New sail swith New jet in furnace Cleaned flume Installed refrig fan and heat sensor New refrig gasket New uphostery New cushion (memory foam) on bed Updated flooring and underseat wood Digital thermostat High end Dometic/Fantastic Fan w/ remote Sliding front window All high grade turnbuckles and eye bolts Backing plates on top and bottom of camper and truck BlueSeas isolator Extra usb and 12v outlets installed in camper CO detector installed Illuminated rocker panel with switches inside of camper Quick connectors for wiring installed Sealed roof, seam sealed interior New style storm flaps (included) Installed backup (OEM) camera Custom made HD steps (removalable bottom step and handrail).
Bad
Battery (AGM) not holding charge; will need a new battery Front Passenger side wheel guards (scraped but touched up with touch up paint) I used seam sealer on window seams (inside)
I'm in Boise, ID.
Truck Item
Camper
Bad
