Ronanmd1
Hey guys - what do I need to do to protect my water system when using shore power. I presume I need a pressure regulator. I picked up one at Canadian Tire. It is an RV water regulator but says it is factory set to 40 psi. Is this too high?
Also, I presume I just connect to the intake, keep the pump turned off, turn on the hose and then just use when I need?
I only used the tank and pump last year and we are heading to a camp spot this weekend that has shore power and water. Figured I better double check before I head out.
Thanks,
Jason
Thanks,
Jason
