Weight
griz
Jun 29, 2009
233
Campbell River, B.C.
I see the Dry Weight of a Hawk is 695lbs. Is this for a shell model or one with all the standard features, or a loaded model? Thks all..................
SPEC'S: KEYSTONE GRANDBY HAWK RANGER EAGLE FALCON SHELL MODELS
Dry Weight 1050 lbs. 795 lbs. 695 lbs. 780 lbs. 690 lbs. 560 lbs. 530-590 lbs.
With these standard features on the Hawk
Standard Features:
All Aluminum “Flex-Frame”
Finished Wood Interior
3 Piece Portable Dining Table
Formica Counter Tops
Deluxe Fabric Cushions
Privacy Curtains
Stainless Kitchen Sink w/ Electric Water Pump
2 Burner Stove w/ Cover
Ice Box
110V System w/ Power Converter
Two Overhead Dual Lamp 12V Lights
12V Porch Light
20 lb. (5 Gallon) Propane Tank w/ Gauge
Fire Extinguisher
20 Gallon Fresh Water Tank
Queen Size Slide-out Bed
Flip Down Couch / Bed Conversion
Large Radius Louvered Passenger Side Window
Safety Exit
Roof Vent
Insulated Side Walls & Roof
Rugged Vinyl Side Liner
Aluminum Exterior Sides and Roof
The "empty" Hawk Shell Model is approx. 560 lbs.
The base model Hawk with standard equipment is approx. 700 - 725 lbs.
A fully loaded Hawk can weigh as much as 1100 - 1200 lbs, depending on how much stuff you load it up with.
See attached sheet belwo that list the weight of each option.
Hope this helps.
  • Weight for Options.pdf
