I wanted to reach out for advice between these two battery systems. Or if you have a better recommendation for the money, I'm all ears.
Mighty Max Batteries (SLA/AGM type):
(QTY 2) 12V, 125AH in parallel to yield a total of 250AH. $500 total
(QTY 2) 6V, 200AH in series to yield a total of 200AH. $440 total
Spec sheets here:
https://www.mightymaxbattery.com/shop/12v-sla-batteries/12-volt-125-ah-sealed-lead-acid-battery/
https://www.mightymaxbattery.com/shop/6v-sla-batteries/6v-200ah-sla-battery/
I am leaning toward the 12V batteries for the extra AH, but also because if one goes down, I can still use the remaining one by itself. I am assuming I could also use it to startup my truck if the truck battery ever dies.
Any comments are appreciated. Thank you!
Spec sheets here:
