Winter liner install
CougarCouple
Sep 17, 2016
1,376
Las Vegas
Morning and Merry Christmas all.
Thought I’d try post up the liner install.
Well first I called and spoke with Jeff, that was easy turn around time easy, opened box that was easy. After looking at what I was about to attempt that was when, I emailed Jeff, please call when convenient, if not convenient please call all the same. ( movie quote)
I would suggest to all that you do that, definitely will make your life easier.
First installed the Velcro along each side wall. Removing three screws at a time, using an awl as I got to each screw hole with the Velcro made it easier to reinstall the screw.
Ok so pretty straight forward, install the panels (this is where the conversation with Jeff pays off)mark for D ring cut reinstall. Second set of hands helpful, being able to reach along the top as standing in the isle is a stretch. Marked the liner, pulled it down punched a hole at either end of the mark for the slit I was about make. Make slit with razor knife reinstall.
Looking and trying to see all that is going on before starting would be the best advice I could give. Aside from getting the tips from ATC guys.
Did not really see much difference when closing or latching the top.
Will try post some more photos.
Russ
I leave my liner up all year. Makes the camper a lot cooler in the summer! And it gives me a place to tuck the window flaps.
