Just upgraded to an 07 CTD with 80k on it. It's a 5.9. Anyway I test drove several like this and it was obvious this truck needed some typical front end work. So I've ordered the new "T" style steering linkage, and a new steering stabilizer along with a steering box brace. Truck has new moog upper and lowers as well as axle drive u joints. My beef other than the wandering that I'll hopefully take care of here is that it jolts the passenger when hitting highway bumps. I'm thinking the shocks may be shot with 80k and they appear to be stock shocks. At the same time I'll be needing new tires to go on the stock 17" rims.
What I'd like to do is to get some sage advice on acquiring the proper solution for shocks and tires for my intended purpose of utilizing the rig as a truck camper with either a FWC Hawk or ATC Ocelot shell type camper. Therefore it will most likely always have a load on the ass end to the tune if 700lbs or so. Lets start with I'm at a point in life where a more plush ride would be welcome. Before you say I should have gone to a Duramax for the ride, or a Ford, I've made the decision for Dodge for a couple of important advantages to the truck, now just need to tweek it as best as I can and without dumping tons of $$$ into elaborate suspension parts.
Shocks and tires is as far as I'll go. So for a plush ride up front and carrying weight in the back, does anyone have experience with this truck camper combo that could shed some light. I use the truck in Bozeman MT in the winter running up and down canyon roads (tires) in the snow for access to water ice for climbing, and similar off road forays to rock haunts in the summer.
Was looking at Bilstein, Rancho, and Edelbrock as this is what seems to come up on searches. I'd even consider one brand up front and another in the rear. Perhaps Bilsteins up front for softening the blows to the front end by the smallest bumps, and Rancho's in the rear to take some weight.
Any insights, mods, tire ideas for my use including size would be welcome.
I realize that most of the time the truck will be on pavement getting from one place to another, and long distances in between for sure, hence the diesel, so tires that are as quiet, will handle the weight of the camper (E rated), and still function well in the snow and shale of the desert would be great.
Thanks a million.... Brian
