docalex
Failed swamp cooler attempt ... and I thought I was so clever... and the fix elegant...
Lesson learned... Suck don"t Blow
Next attempt ..... Swamp cooler panels
The little panel in the pass through window pulls cool air right across the lower bunk... Winner for sure ... stores easily and set up in a couple of minutes.
Next Level ... I am experimenting with the other panels I have available.... Pulling air through the side windows does cool the air but the flow is not directed in the proper direction.... I think the best solution is going to be replacing the fixed cabover window with one I can open ... and place a swamp cooler panel there... nice and close pulling cool air right across the sleeping area
