I spotted this thread and decided to give it a try.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/17575645/srt/pa/pging/1/page/1
It cost a bit over $20 but the parts etc were easy to obtain. I used gutter guard and two types of vinyl drip edge. It took a total of about 6 hours to make but that's mostly due to working in near freezing temps in my carport. The adhesive was really slow to set and my fingertips were definitely less than accurate. I modified it a bit narrowing the front section and lengthening the sides. Given a 70 degree day I could probably duplicate it in a couple of hours.
My original intention was to use only existing screws (4) but ended up adding 2 more on the front section. If you can find clear pvc "primer" that would be the best surface prep, I wish I hadn't applied any of the purple stuff.
It is surprisingly strong and seems to work. I've run 85 mph into a pretty good headwind without any problems. My only testing tho' was sticking my hand out the window and feeling the air blast in different places. It sheds a lot of air along the sides and there is only a small amount of turbulent air "inside". I guess the final test will be when the snow melts and the bugs come out and it'll be interesting to experiment with plugging some of the hole sections.
Now if I could only find a Thule or Yakima deflector that would direct air into the airfoil from just over the windshield I'd be set.
The pics are before the final mounting with the weatherstrip foam.
Rob
Rob
