2005 Toyota Tacoma 4x4 TRD Sport Double Cab Long Bed + 2003 Four Wheel Camper Eagle
mikep
Oct 25, 2019
20
We are selling our setup as our family is growing and things are becoming tight in our little camper!
The Truck:
2005 Tacoma TRD Sport 4x4 Double Cab Long Bed
-The TRD sport package has a mechanical limited slip differential, and also a larger sway bar than the TRD off road, which is why I sought out this truck for a FWC, so it handles great. (also sport seats)
-Four Wheel Camper Bed Brackets
-Firestone Air Bags
-Full service records since new, starting with the window sticker (we are third owner)
-In the last year I have had a lot of work done to keep it mechanically perfect, to match my meticulous upkeep including-- brakes (calipers, discs, pads, drums, shoes, wheel cylinders, brake booster), wheel bearings, East Coast Gear Supply clamshell bushing (don't buy a Tacoma unless this has been done!), belts, alignment, prob more, have receipts for all done professionally.
-187,5xx miles
-Custom waterproof seat covers, can't remember brand,
-Rubber TRD mats
-Tailgate included, of course
-This truck starts, drives and stops like new. It is exceptional for the mileage, as you can see from the pictures.
-All wiring for camper uses marine grade hardware, with redundancy on the breakers for solenoid
-Tow Package with transmission cooler
-Avg an honest 16.8 MPG on most trips
-Clear title, absolutely zero accidents, one small dent behind driver's rear wheel
The Camper:
-New vinyl floor, floor pack inspected at that time, good to go.
-New rear door
-Rear bike fork mounts for carrying bikes vertically. They are out of the way completely, so you can always get into the camper without have to mess with them.
-Sink with manual pump, two burner stove and ice box, fresh water tank
-Heater is an Olympian Wave 3 Safety Heater, definitely the most efficient heater available, and it cooks if desired.
-Northstar AGM battery, brand new. Meter doesn't show a drop after 3 days of lights and charging devices etc. It was around $300 I think. This setup does not need solar, and you never have to worry about using power.
-Added USB charging ports
-All LED lighting
-Modular table
-Marine epoxy reapplied on bottom for extra protection
-All stainless hardware
-Added diamond plate for extra protection
-All new trim when switched over to stainless hardware
-Vinyl/canvas in good shape, a few pinholes in the corner were seam gripped
-Switches/breakers installed so you can turn on/off all lights and power while standing outside at the back door, you'll get why if you use it, very handy.
-Roof vent
-Four Wheel Camper factory luggage rack
The combo works awesome together, very easy and capable.
$24,500 OBO
Thanks,
Mike - Located in Bellingham WA
(925)330-8775
(More pictures coming)
More pictures...
And more...
...and more...
...and more...
...and more...
...and more...
...and more...
Last ones--
