wanderspring
******SOLD******
Our Four Wheel Grandby is up for sale. This 2007 Grandby is fully loaded, has some upgrades, is in great condition for it's age, and is ready to throw on your truck and head out to camp this weekend.
Three way fridge
Two burner propane stove
20 gal fresh water holding tank
Fresh water & battery monitor
Sink with cutting board cover
Propane heater with thermostat
Propane water heater
Outside shower
Dual batteries (optima yellow top)
Side awning
Exterior rear lights
Mechanical jacks, with hand crank and drill adaptor
Side table
Folding couch
Portable chem toilet
Screen door
Roof vent with 3 speed two direction ceiling fan
Full roof rack (cargo rear and cross bars for boats/boards)
Sliding front window (to access cab of truck)
Venting side window with screen
Rear window
Window in rear door
110v and 12v outlets
Smoke detector
LP detector
Fire extinguisher
Upgrades:
Custom 5 gal grey water holding tank - makes this camper fully self contained!
Tie down eyebolts reinforced (the usual method used on these campers)
Steel plates added to jacks. Increases the width between the jacks to accommodate wide truck beds
2 of 4 interior bulbs converted to LED
2nd optima battery
There are some nicks, dings, dents, scrapes, and scratches. One of the clear vinyl windows, and it's grey cover have been repaired.
Will include all original manuals (stove, fridge etc.), pigtail wire for truck, truck bed eye bolts, 4X turnbuckles, truck leveling ramps, fresh water hose, grey water hose
~800lbs dry
96" front to rear. The Grandby model is 8 feet long, but will fit shorter beds with tail gate down. We ran it on our short bed crew cab Tundra with tail gate down.
21.5 inches bottom of camper to underside of the side over hangs (truck bed rail height)
Our Tundra truck bed rails are lower, so we set the camper on top of a 1.25" spacer.
49 inches from bottom of camper to underside of cab over hang (truck cab height)
$10,500
Go here for pics: http://reno.craigslist.org/rvs/5799272034.html
tahoecruize (at) gmail (dot) com
Thanks,
ANDREW
Three way fridge
Outside shower
Side awning
Side table
Folding couch
Screen door
Rear window
Window in rear door
Smoke detector
LP detector
Fire extinguisher
Upgrades:
2nd optima battery
~800lbs dry
$10,500
Thanks,
ANDREW
