2015 ram 3500 lone star mega cab bundutecusa odessey flatbed camper 81,xxx miles
Tugvi
Feb 15, 2020
12
Truck has navigation, heated seats, heated steering wheel, electric driver seat, manual passenger seat. Stock suspension and motor other than leaving kit/cold air intake/tuner (I wanted to be able to go to any dealer and grab parts that could/might get damaged/go out). I still drive the truck so the mileage will change. Always serviced on time. Oil change usually done early due to way it is used. Complete list below of things done to truck. It has the heavy duty Aisin transmission.
List of modifications front to rear.
Midland cab antenna
•wee boost antenna
•road armor stealth bumper
•smitybilt 17.5k winch with wire/Bluetooth remote steel cable
•kc 45inch cured led light bar
•mm3 with 6 tunes to run any diesel fuel even that nasty Mexico high sulfur
•8 switch spod touch screen
.national Luna dual battery controller/monitor
•midland cv radio
•wee boot controller
•tuffy center console lock box
•rear seat platform
•10 gallon front runner water cell gravity fed under platform
•arb twin air compressor
•national Luna smart solenoid
•Firestone 3 gallon air tank
•auxiliary battery
•bundutecUSA oddesy 205 flatbed camper(more on that below)
•cm aluminum flatbed
•bw gooseneck hitch with hatch in flatbed
•rotopax duo mounts 2 diesel/2water
•air lift air bags
•longhorn 20s with nitto g2s 295/65/20
2017 BUNDUTECUSA FLATBED CAMPER
•22 gallon water tank
•led outside lights
•dometic fridge and cooktop
•Lagun table with solid cherry top
•12 inch memory foam queen mattress yes your read that correctly a 12 inch mattress.
•upper shelf storage
•max air fan
•ladder and 3 bar roof rack
•electric roof jacks
•Chinese diesel heater
•his and hers clothing hamper on either side of bed
•pelican 1650 turned into outside storage/cooking area
•alucab 270 awning
•2 bike bike rack on ladder
•c dinette that can turn into small bed with table top.
•110 outlets (only with sure power no converter)
•knife magnet
•6 gallon propane hot water heater
•20 pound propane tank
•manual happijacs
•4 anchorguard tie downs
Faults/issue
•Pin striping in various places it’s been used you will make more
•2 screws popped out on fiber glass in cab over never got wet happed on way home from picking it up was immediately covered with pool patch.
•was rear ended prior to modification with damaged rear bumper. No major damage but is listed as accident in vin report. Bed repainted due to screeched flatbed 2 years after.
•2nd owner with 25k miles. Was stock other than leveling kit and bw gooseneck was older gentleman that pulled camper and wanted a longhorn.
90k firm currently located in memphis tn
Love the truck and camper but thinking about moving back into the jeep. A lot less think-less when out on a long hike and vehicle is just sitting.
pics
pics
pics
