2024 Tacoma with FWC?
Twenty or thirty years ago I would have had no problem buying a first-year model from Toyota. I can understand the hesitancy to do so now, although a lot of the furor has been caused by those always itching to find cracks in Toyota's armor. The company did step up with the Tundra engine issue by issuing a full recall, rather than insisting on waiting for individual failures. And, ironically, there's nothing fundamentally wrong with the turbo V6; it was a simple failure to adequately flush the newly made blocks that caused the issue.
I think the new turbo four in the Tacoma is a far better engine for a truck than the previous rev-happy V6. The new boxed chassis is infinitely superior, even in the base, rear-leaf-spring version. For the upper level models, coil springs are far easier to upgrade than leafs. The front anti-roll-bar disconnect is more usable on a regular basis than a front diff lock. Many, many improvements in the new Tacoma. The only major goof I can see involves the silly "IsoDynamic" seats in the TRD Pro, which are standard and completely eliminate rear seat leg room.
always appreciate your 3cents. fwiw - i just bought a 21 toyota access cab for running around. i may be looking at better seats though.... will see
I talked to FWC and there are no issues with mounting a new FWC on a 2024 Tacoma. Just need to tell them it’s for a new Tacoma when ordering camper.
So if I decide to go with a 2024 Tacoma, I would still need to decide how to upgrade the suspension to work with a new FWC Fleet Shell which is significantly lighter than a fully furnished Fleet.
I called ALCAN Springs and they said they are developing a leaf spring conversion kit for the 2024 Tacoma. Interesting, but is replacing the coil springs with leaf springs a good answer?
Where can these coil spring upgrades be obtained?
Since the FWC Fleet Shell is a lighter unit, maybe a solution or possibly temporary solution would be to get airbags, but another poster said that airbags don’t work with coil springs.
I keep going back and forth on getting a 2022 Tacoma vs a 2024. I realize the new Tacoma is untested but all those new upgrades are tempting.
To summarize, I’m just trying to figure out how to upgrade the 2024 Tacoma suspension to handle a Fleet Shell which weighs about 700 lbs minus the gear we would be hauling. Any suggestions are greatly appreciated!
It may take a few months for the aftermarket to catch up, but I am sure there will be a slew of aftermarket heavier coils for the 2024 tacoma available shortly. You also can use airbags with coils - it is even easier than with leafs.
To add - I was an 'early adopter' with the first year of the prior generation of Tacoma. There were all the same fears and discussion on the forums about it. 50,000 miles of adventuring later, I am still happy.
Try RV LIFE Pro Today
