64 window trim
Oryguntroutbum
Dec 15, 2012
396
Central Oregon
Anyone know if this type of trim is still available, and if not if there is a suitable replacement?
Thanks in advance.
I really like Vintage Trailer Supply. Their catalog is located at: http://www.vintagetrailersupply.com
I purchased several items from them and found them to be a good outfit to deal with.
Mike
Mike
Thanks Mike. I have looked through the site a little bit based on some other suggestions on this forum (maybe from you). I'm ordering some of the teardrop shaped lights tonight from them to replace the current ones. I'll see if I can find that type of trim too.
Thanks to Mike from here as well. I learned of Vintage Trailer Supply through his posts on here.
I found http://www.vintagetrailersupply.com/Hehr_Standard_Glass_Seal_p/vts-195.htm to be an identical replacement for the Hehr jalousie windows on my 60's era 8' NCO.
if the seal isn't the same, i redistributed my seals that had shortened. i moved them so that seal lined the window all around the top and sides and the un-sealed area(about 2")was at the bottom center and filled in with clear flexible sealant.works great.
wes
I know you've found the gasket...could you take a picture a little ways back away from the installation...
I'm not familiar with the location of that gasket...it looks like inside trim?...or is it outside trim?...mines not built like that....just for the information
Thanks guys
Thanks guys
It's just a close up of the louvered side windows from the early to mid 60's. The smaller panes of glass were sealed with this gasket.
