Mr. Grandby,
Well, so far nothing has been fixed although I've convinced, myself at least, what's to be done.
FWC has agreed that exterior fridge venting should be in place and committed to installing both upper and lower exterior vents. We are waiting for the vents to be shipped to Oregon where the Tigard distributor will do the installation. Once vents are in, we need to close up and seal off ineffectual interior vent spacing above and below the fridge to mitigate intrusion from dust and insects through the new exterior vents.
My plan here was to use expanded foam board above and below the unit to both close those gaps and increase insulation to the box itsself. I thought I could additionally use foam sheets attached to the unit back not only as additional insulation to the fridge box but as baffling that would serve to channel incoming air through the bottom vent, up and across the compressor, cooling fins, the compressor fan, then out the upper vent. The convection and flow of this air stream is to be assisted by 2-120mm BB fans blowing the heated air out through the upper vent. My thinking is that if all new air is directed past, over and through the cooling mechanism there is no need to cool the lower dead space behind the fridge unit. The two small fans theoretically draw .22 amps each at full speed 1350 rpm. Of course, that's manufacturers specifications when new. Even though they have twin ball bearings I suppose that number will increase over time with wear etc.
I'm not the sharpest tool in the drawer when it comes to refrigeration or electricity for that matter, but I do have a sense for fluid flow and aerodynamics.
The lower part of my 2-way Dometic is just a cooler box. The upper is the mechanism for dissipating heat. Doesn't it make sense to channel all available air past that heated area rather than have it swirling around where it only would serve to warm the area we're trying to cool?
Grandby, I like your idea off a temperature switch. No use running the fans if unnecessary.
Although thinking I'm a smarty pants with the foam baffling...I don't know. I suppose the compressor fan and convection would do the work. After all, any air movement has to go right over and through the only open path. Can you give me some recommendations about a good switch and where I can get one and some additional details about your installation?
I'm all ears if someone wants to chime in here. I've been known to overthink just about everything I come in contact with!
I appreciate every comment, truly!
T
T
