Sweet. Pipe up when you want electrical help....
Awesome!! I'm currently trying to figure that out.Vic Harder said:Sweet. Pipe up when you want electrical help....
Perfect, Thanks for the website, much cheaper there compared to other places. I'm placing a order for some 8ga and 16ga. As well as the Blue Sea 5026 Fuse Block, Blue Sea 4365 Accessory Panel and a 4.8A dual USB charger. There goes $200, money well spent though.Vic Harder said:Bert, the Blue Sea gear is very nice, and is what I use a lot of. Note that you likely do not want to use 12g duplex (house) wiring. The vibration will not be good for solid wire. A nice pre-tinned marine gauge stranded wire would be better, in a variety of gauges. 8g from battery to fuse panel, and 16g for the individual circuits, for example.
For your USB ports, consider the Blue Sea gear. I got one of these Blue Sea Systems 1045 Fast Charge 4.8 Amp Dual USB Charger (pkys.com) and put it in one of these Blue Sea 4365 Water-Resistant Accessory Panel with 15A Circuit Breaker, 12V Socket and 2 x 2.1A Dual USB Chargers (pkys.com)
hi vic. where do you put those led light strips in your pop up? i have an atc shell, with their factory lights in roof, but will need more lights aroundVic Harder said:I used these lights. I have 4 strips in mine, which is very nice and bright with no shadows. note the pricing is in Canadian funny money...
EShine 3 Panels 40 Inch Extra Long LED Dimmable Under Cabinet Lighting Kit. Hand Wave Activated - Touchless Dimming Control. Cool White (6000K): Amazon.ca: Tools & Home Improvement
On top of the wooden trim slats, and centered so that they don't interfere with the roof lift panels.goinoregon said:hi vic. where do you put those led light strips in your pop up? i have an atc shell, with their factory lights in roof, but will need more lights around
