Bombsight Build Thread
Bombsight, can you give us some more details on the Quick-En-Suite shower?
How do you like it after several months?
Who did you order it from, how much, and how was the delivery time?
How does it "play" with the other exterior fixtures (water heater exhaust, electrical plug, water inlet, etc., furnace exhaust)?
A brief rundown on how you installed it would be interesting too. We have a Hawk with the same exterior layout as yours.
IT'S AWESOME!
Yea, its also expensive but considering how long I think it will last, it's really a fair price when you consider the quickness of not only set up, but take down time.
Camping is supposed to be fun, relaxing and without the pressures of every day "Do this do that". The ease of setting this thing up and putting it away eliminates the "Ugh, I'm not going to shower tonight because it's a pain in the ass setting up my Bush league shower system". 'Nuff said about that, tight?
I ordered it directly from the distributor. I think that link is posted a page or two back. They were on back order but if I remember right, it still only took 6 weeks.
I have not used it while running the furnace (I live in the south) ... but other than that, I see no issues with its mount location. I have a 2016 side dinette.
It's possible to mount with one person but two people make it MUCH easier.
The bottom right mount hole is located about 31" forward from rear back corner of camper.
The top edge of the shower box is mounted even along the caper tops bottom edge.
A cardboard pattern (with mounting hole position) should be made prior to drilling mount holes - check inside for hole positions as well) just to make sure everything is as wanted.
The shower box should be raised slightly away from side of camper wall in order to keep the camper tops edge from hitting it. It should be raised away from outer wall to allow for walls top moulding edge to clear underneath as well.
You can do that with these: https://www.ebay.com/itm/Four-Pack-Penn-Elcom-9106-Rubber-Cabinet-Foot-2-5-Dia-x-1-H-Heavy-duty-Black/371955015134?hash=item569a3f1dde:g:a6wAAOSwGotWjVdh
I think I used 3/8" stainless bolts/lock nuts (lock nuts on the inside of camper) along with fender washers inside. I don't remember the length of them. You may have to drill the shower box mount holes bigger for 3/8" bolts.
Take your time if you decide to do it but imho, its more than worth the 2 day hassle it is.
I looked all the way back to several pages before your shower got delivered, couldn't find who you got it from. Did some looking today and it seems like it is not available in the US any more.
:eek: Wow
Here is some info I pulled from an email the distributor sent me. Hope that helps.
Thanks! I'm not sure if it is a website issue or what but that site has been down all day. I've got a janky setup for now, and I'm sure that product will be available in the states again.
Front bumper installed:
Warn Ascend Bumper
4 rigid Industries
2 Baja Designs LP9's
Warn Zeon 12-S winch
Factor 55 Hook
Expedition One makes one awesome kit!
Stoked after trying to get a dual swing out bumper for THREE YEARS!
Expedition One made a custom one for me. Communications were awesome and delivery / fabrication time was spot on from day one!
