Do you have access to another inverter for testing purposes? This is more than a little strange. If the battery on the ebike is totally flat, what does the manufacturer say the time required is to recharge? (that will give us some idea of the charging current). Inrush would be unlikely to be more than 2 or 3x that, I would hope. I'm betting it is way below 100A, which is what your renogy can put out for short while before overloading. Or maybe you have access to a clamp on amp meter? or some other way of measuring higher currents? Most multimeters tap out at 10A.
