Mthomas
Hi all,
New owner, only have two weekends under my belt, so everything is new to me at this point.
While loading up in the driveway last friday, I decided to hook up the city water connection just to see what that was like. I used an inline pressure regulator to avoid any overpressure issues. Heater filled, tested faucet in sink and external shower, everything worked fine.
I then removed hose, and put about 10 gallons into the water tank. I then opened the drain valve under the sink and opened the faucet to allow the water in the heater to drain back down into the holding tank while I loaded rest of weekend supplies. As far as I could determine by the sounds, this was successful.
Over the weekend, I noticed a persistent drip from the city water inlet when the water system was pressurized. It was enough to leave a largish, 1 foot in diameter, wet spot on the ground next to the truck. both mornings we were out. I kept wiping off the drip line on the side of the camper to see if it discontinued, but the leak persisted.
I also noted that the water pump was kicking on occasionally for a fraction of a second whenever the system was left pressurized, but not in use. This was what made me start looking for a small leak in the first place.
My question: is this normal behaviors? I do not recall seeing this before I tested the city water system. Is there some sort of check valve in the city water inlet to prevent back flow from the internal system when pressurized which may be stuck slightly open?
Anyone really torn into a more recent plumbing system? Any thoughts? I do have a call in to FWC, and will be calling the dealer i purchased from as well.
