Coffee maker?
I'm still using that same old plastic one cuper that uses one of those Melitta filters that I started with when I bought my Granby 12 years ago. I just change the coffee type and grinding method ever so often-sometimes pre- ground -sometimes not! Why change a good thing. Come to think about it-I think I was using it before then, when I was back packing and truck camping!
Smoke
CougarCouple said:
Hi Vick
I don't think my shoulder could manage that , I'll suffer thru the instant for that mistake. :)
Russ
This is pretty good quick fix.
+1 on the instant espresso. A little goes nicely in a cup of hot chocolate.
CougarCouple said:
oooh. sorry to hear that your shoulder is that bad.... maybe consider it coffee therapy? ;-) Maybe with some rye in there for a pain killer?
Starting the day with good coffee is one of the keys to a happy life (and a happy wife). :D
My criteria are: 1) Coffee brew quality, 2) weight and size, 3) ease of cleaning, 4) simplicity, 5) makes up to 4 cups at a time.
I've tried various coffee making methods over the years, but this is what I'll be using this coming summer based on camping and kitchen trials this winter.
Coffee maker: Stanley Cook & Brew. It's a very good French press--Simple, makes excellent coffee, fairly compact and light, easy to clean, makes up to 4 cups, and doubles as a water pot. Perfect for 1 or 2 people. The downside is that it's not insulated, but one could make a simple cozy out of Reflectix or just pour into an insulated coffee cup, which is what I do. Learned about this coffee maker from a review by Chris Cordes over at Expedition Portal.
https://www.amazon.com/Stanley-Stan-Press-Stainless-Steel/dp/B01H7MK3IC/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1515409404&sr=1-2-catcorr&keywords=stanley+press.
Coffee storage: I use an Airscape canister at home for storing a week's worth of beans and it's the best solution I've found for storing ground coffee as well. As you all know, quality coffee and airtight storage are as important as the coffee making method. I'm traveling in my camper away from home for 3-4 months at a time and I'm sometimes a couple of weeks between sources of good locally roasted organic coffee. I don't want to fuss with a grinder, so I need to store ground coffee. This thing works by means of a simple french press-like plunger to purge air from the canister. The Airscape can store 16 oz of ground coffee (or 12 oz of beans). It makes a noticeable difference in freshness and it's relatively light and compact.
https://www.amazon.com/Airscape-Coffee-Food-Storage-Canister/dp/B00167XN14/ref=cm_cr_arp_d_product_top?ie=UTF8
And it should solve another problem: Last summer, I picked up some freshly ground and very aromatic French roast from a roaster in Flagstaff in a typical waxed paper coffee bag. I stuck it in a cabinet and hit the road for a day of traveling. Every time I stopped, my CO2/propane alarm was blaring. The gas was off and the lines were purged so I was pretty sure I didn't have a gas leak. I even moved my backpacking fuel canisters to the cab, just in case. I couldn't detect any odors, in part because of the pungent freshly ground coffee. But it kept happening every hour or two. As an experiment, I moved the coffee to the cab, drove for an hour, with no alarm; I moved the coffee back to the camper, drove for an hour, alarm triggered. Problem solved! (That was some good coffee!)
For home I use a rancilio Silvia and rancilio rocky grinder. Camping I use the Aeropress with stainless filters. And a stovetop steamer for the perfect latte. Rancilio Silvia Espresso Machine with Iron Frame and Stainless Steel Side Panels, 11.4 by 13.4-Inch https://www.amazon.com/dp/B00H1OUSD2/ref=cm_sw_r_cp_apa_ew5uAbV7SWAZ1
Rancilio HSD-ROC-SS Rocky Espresso Coffee Grinder with Doser Chamber https://www.amazon.com/dp/B00H1OUSL4/ref=cm_sw_r_cp_apa_0w5uAbW7BH8Q6
Aeropress Coffee and Espresso Maker https://www.amazon.com/dp/B0047BIWSK/ref=cm_sw_r_cp_apa_Hx5uAb6WP276D
S Filter - The Original Mesh Filter for AeroPress - Built in the USA and Guaranteed for Life https://www.amazon.com/dp/B00A1GVVMY/ref=cm_sw_r_cp_apa_5y5uAb6WWS9T7
Stove-Top Cappuccino Steamer https://www.amazon.com/dp/B003GCYGGS/ref=cm_sw_r_cp_apa_Yz5uAbKZ3BRY3
I love coffee, but all of this is just too much time, space and trouble when I am in the camper. I just switch to instant or tea. I am going to try that instant espresso.
cwd
ROK if you're into espresso. I have several Moka pots but the coffee tends to boil which kills the flavor for me. My grinder is a Hario mini, but I cheat by attaching it to my Milwaukee angle drill instead of hand cranking. I also keep a Sea To Summit collapsible drip cone in the camper and when I'm really lazy or in a rush Starbucks Via instant (my backpacking fav)!!
Bob, This is the equipment I've been exploring, but I can't put that kind of money down without trying a well made coffee/expresso first. I've never had the opportunity. All I know is I'm tired of giving Starbucks $3.10 every morning, especially when they typically serve me a cold coffee.
I should point out that I have owned my Rancilio for over 15 years and it still has crema from the beginning of the brew, way better than Starbucks. My wife and I each brew twice every day (4)
Sent from my SM-G930V using Wander The West mobile app
Bill D said:
What type of water do you use?
Do you order your beans from a roaster?
Bill, a Calgary company that will deliver to commerical clients is Phil & Sebastian's. Best coffee I have ever had - single estate, small batch, direct trade.
Have you considered an Elektra Microcasa ? I used a Brewtus Expobar for years and like most espresso machines it needed maintenance from time to time. It got to the point where finding parts was getting near impossible so I replaced it with an Elektra. It pulls great shots - some of the best I've ever had. I home roast my beans so I have a new batch about every 4-5 days. The biggest challenge is getting the grind dialed in for each batch. If you use the same beans all of the time, this isn't really a problem - but I like variety.
BTW - Rancillio makes great espresso machines, but with a lever pull you have control of how fast/slow the shot is pouring. Whichever way you go you'll be saving $5-6.00 per day = $1800 year for far superior coffee!
https://www.home-barista.com/reviews/elektra-microcasa-leva-review-t33371.html
The most enduring coffee maker I have is a 'Press Bot' by Canyon Coffee.
The ingenious folding press fits into a liter Nalgene bottle and makes great coffee. Still using the first one I bought nearly a decade ago, it's seen a lot of use on the trail and the fireline.
http://canyoncoffee.us/press-bot/
Way too rich for me. I couldn't see spending more than $1000 and to me that even a big stretch. Beautiful to look at though. I did spend about $700 on a Vitamix and accessories though :oops:
I'll have to make some new coffee friends. I did a quick Google search on coffee meet-ups but only found people wanting to meet at coffee shops for companionship. I'm sure if I search a bit more I can find coffee groups in my area that are actually passionate about coffee. It would be interesting experience to go at least a time or two.
I hosted a photography meet up for a couple years, so I'm quite comfortable with them.
I might just try out some smaller coffee shops as a start.
Love to see so many coffee junkies,I'm not seeing a lot of consensus but many many ways to to make our elixir.
My $0.2 press or cowboy, both are good for me. Fortunately my taste buds are not particularly snooty,I just keep adding grounds till I get the desired affect. speaking of which I'll have one cup and on my feet.
Cheers
What better way to start the day than coffee on the rocks!
Davis Lake in the Cascade Lakes region of Oregon has a number of campgrounds along it's eastern edge and is a favorite destination.
