It's not a contest, it's an exchange of information and we all learn in the process.
DIODES
According to this WiKi page on diodes, "While standard silicon diodes have a forward voltage drop of about 0.6 volts and germanium diodes 0.2 volts, Schottky diodes voltage drop at forward biases of around 1 mA is in the range 0.15 V to 0.46 V, which makes them useful in voltage clamping applications and prevention of transistor saturation.", so again unless we KNOW which diode is in play or we put a VOM on it, we don't know the voltage drop.
If only .15V and zero wire loss, we get a little over 80% charge; if .46V then we only get about 55% on an FLA battery (see below). Neither of these is acceptable to me, esp considering the cost of a diode isolator vs a relay...
However, I DON'T know what other magical components/circuitry there may be potted up in that black box to compensate for the various diodes' characteristics. Only way to really know is hook one up in a charging situation and measure the voltage difference between input and output with a good VOM.
I'll also fall back on the advice of folks on other RV lists, the guys with the BulgeMobiles who carry two, four or even six 6V golf-cart batteries, and the electronics geeks who know a lot more than I do about theory and they all seem to choose relays over diode isolators.
WIRE GAUGE
I believe 10g is not adequate, except for very short runs, because that's what started this current thread -- We apparently have a battery (AGM) that will accept a lot of current and a charging system that will provide same, connected by a wire and fuse that seems too small -- Looking at the cabling chart in the Intro... PDF, 10g is only good up to 12' for 40Amps.
Last time I went to an RV show, I noticed that the travel trailers were now using either 8g or 6g for the 12VDC connections to the house battery, where in prior years they were typically 10g.
PARALLEL CHARGING
Batteries in a bank should indeed be as identical as possible, but batteries separated by wiring don't seem to suffer as much in use according to what I've read and experienced.
It does occur to me that if the wiring is so oversized that the two batteries appear electrically side-by-side there may be problems, esp if one is an AGM and very discharged. If I had that situation (and I won't unless the price of AGMs comes down quite a bit), I would have a way to disconnect the house battery until I had the engine up and running and could leave it that way for a while.
RELAY
I'm not sure I buy into the "copper coils in the relay" messing with the charge. Seems to me that a proper design would account for that.
I do believe the relay should be sized for handling a constant heavy load consistent with the alternator's output.
DIODES
WIRE GAUGE
PARALLEL CHARGING
RELAY
