steve whiteside
The cycle of the heater was roughly 5 min on and 15-20 min off. I have whatever the standard analog thermostat that came with my new FWC camper.patrkbukly said:Sounds like you did well in the Granby (i think granby) Steve.
Which thermostat do you have?
6 days from one propane tank means you went through a lot of fuel but if you slept well and got through it all fine sounds like things worked as they should.
also im curious as a comparison to what mine does in similar conditions...how often would you say the furnace cycled on and off in that 37 to 57 range you stayed in?
Nice setup and rig by the way. I like the FWC’s in black. I think that was a smart move on their part.
patrick
The color is actually dark grey. I debated about white since most of my camping is in hot places. Im glad I got the dark grey though because 1) I like the looks and 2) the added heat load is not that great because of the awesome ventilation with the pop up windows open. I believe that the color of the outside shell is negligible compared to the amount of heat that can be removed from the inside of the camper due to the breeze blowing though. That is my opinion anyway.
