Creaky suspension on Tacoma
Marmot-WTW
Aug 19, 2017
13
Tacoma, WA
I have a Fleet on my 2017 Tacoma. The truck has about 50K miles on it, 90% put on it since the Fleet has been on nearly full time. Its suspension (I think) has been creaky for a long time, and recently it seems to be getting creakier. I have ARB leafs, OMB shocks, and Firestone airbags. Is this a sign of a serious issue, or does the suspension just need some lubrication or something?
Toyota 4WD's are well known to creak when the suspension moves at full lock in one or both directions. More common with the IFS trucks prior to the Tacoma's, but I understand that all vintages of Tacomas will do this occasionally.
I am suspecting that is not the source of your noise.
The OME springs use a hard urethane bushing rather than rubber like OEM. Those will tend to make noise unless lubricated, and sometimes even with lubrication. I've been told by one 4WD shop owner that all urethane bushings will eventually squeak, and once they do squeak that you may as well replace them because there is no effective, long-term cure that he knew of.
I've been impressed by the OME bushings because they are a clearly superior material to those urethane bushings sold in the US aftermarket. However, if they are squeaking it may be time to consider replacing them. I would strongly suggest talking to Cruiser Outfitters about this as Kurt is a long time OME dealer and can best advise you on the path forward.
My tacoma w/ OME shocks and front springs, and Deaver leafs + airbags in the rear, squeaks a lot.
I have been told that the Energy Suspension silicone grease is the best for use on urethane bushings. Dielectric silicone grease is a viable, but poor second, and anything petroleum based is a bad idea because the petroleum chemically attacks the urethane. Used to be that Baker Precision sold a similar silicone grease for suspension bushings, but I'm not finding it on their site.
https://www.energysuspensionparts.com/formula-5-prelube-bushing-lube.asp
I bought that lube.... then realized I'd have to disassemble my truck to apply it.. It's not like a spray that will seep in, or something w/ grease fittings. You'd have to remove the bolt from the bushing, grease it, then re-install it.
I'm a little more confident w/ my truck repair abilities since I bought it, so would probably try it now... if I still cared.
On some of my cars that I put delrin/urethane bushings in, I drilled/tapped and installed zerk fittings so I could grease them up without disassembly.
I've been told that any high-quality synthetic silicone grease should be fine for polyurethane bushings. I use Superlube or Amsoil.
One thing to note is that the tip pads on OME springs should be lubed now and then. The easiest way to do so is to jack up the vehicle by the chassis so the springs hang free. Then you can use a pry bar to separate the spring ends, clean off any dirt, and insert a smear of grease. You might be surprised to note a difference in ride quality as well as a reduction in noise. Those pads can and should be replaced when they wear out.
Another thing to keep in mind regarding bushings is that usually the rotating—and thus squeaking—part of the bushing is the inside, where the pin goes though. The fat outer part rarely rotates. If it's lubed when installed it should be good for the life of the bushing; the center grease nipple (on OME and some other shackles) is then used to periodically lube the pin.
I have owned a '93 MR2 since 2000 and in 2003 I had the rubber bushings replaced with polyurethane. No grease but they only squeak when I first start out, then the squeaking just stops or I just stop hearing them.
