Dc-Dc charger and Ground
Jollyrogers
Feb 2, 2015
159
So when I ran 6awg from truck to my non-isolated DCDC 30amp charger I ran both + and - the whole way. It works ok it seems. But in hindsight I could have saved some$ I think. Other than saving on copper, and finding another use for it, would I gain anything by just taking the -/ground to the truck frame?
I guess you could save a bit since the neg terminal on the battery goes to the frame. When I ran my wire though, it was a 2 strand wire but never thought about just purchasing a single strand wire and then buying a shorter piece for ground.
The benefit would be that you could run a thicker guage single wire that would be the same thickness as a double wire. Um...
I can’t locate it now, but somewhere I’ve read that resistance through the vehicle frame can be higher than you think.
