goinoregon
you are braver than me! i would be concerned about crossing that creek without some partner verhicles around
ramblinChet said:Thank you kmacafee for introducing me to this product.
OK, I have been thinking for months about how to mount my four MAXTRAX in a secure location while still being able to retrieve them quickly. The roof was a consideration although most all of the area will be occupied by solar panels and even more weight on top of a pop-up is not a good thing. In the future there should be a rear swing-away tire carrier module for my AEV rear bumper but it may not provide for securely mounting MAXTRAX.
Here is the Trax-Clamp manufactured by Quick Pitch in South Africa:
This will bolt on to the side of my FWC and will accept all four MAXTRAX
Here is the lever which captures two or four MAXTRAX and can also be locked
Pop the lever open and seconds later MAXTRAX are available to use - no ratchet straps, bolts, etc.
