Fantastic Fan opens itself and destroys itself: Easy to Remove and Replace with MaxxAir?
My truck is a big crew cab and the camper overhang starts at about the front of the rear doors. Can those who have had this problem please post what their truck cab configuration is? I’m wondering if shorter cabs might be worse for this due to differences in airflow.
We have an extended cab; the front of the camper overhang is within 6 inches of the top of the windshield. Also, we have only experienced the problem with the front vent.
In doing some additional research and talking with people who really understand aerodynamics, the consensus is that if the vent had been installed 6-12 inches or more further back, the air coming over the nose of the camper would not have affected the fan.
I could be wrong but yours is not a FWC and the front vent on your camper is very close to leading edge...I don't believe that any model of FWC has the vent that far toward the front of the top....also in mix is what else if anything you have on the roof...my two solar panels undoubtedly disrupt any laminar flow over the 2 FF vents...as speculated before , the type of camper mount, sitting in bed or on a bed frame and aero dynamics of your truck style could be factors...wish someone would post a series of photos showing the damage and suspected weak components...
You are correct, it’s not a FWC but I believe some with FWC’s have had the same problem. And this problem seems to be limited to front vents. There’s enough disruption of air moving across solar panels, air conditioners etc. that the rear vents are rarely affected.
As the air moves up from the windshield it will fall back downward onto the roof causing dirty air and a vacuum effect. So the air can actually be lifting the vent up ward. Air moving up the windshield has a positive pressure when it clears the roof line it is being sucked back down by negative pressure on the other side. I'm in a rush so I did not explained it very well....
I have a Yakima wind deflector just above my windshield, more to keep rain and debris out from under the Hawk over hang on my '05 Tundra AC and off the small tray of emergency gear I constructed on the Tundra roof using Yakima towers...anyway...the issue of aerodynamics notwithstanding...seeing actual photos of the damaged FF vents would be very helpful..
Pvstoy I think what you are describing is similar to the lift above an airplane wing where air moves faster over the curved surface creating less pressure there and hence lift...I could be wrong on this...
I was thinking the same thing. It's similar to the uplift created by wind over a plane wing.
We replaced our FF with a Maxxair and have been very happy with the quiet 12 speed fan with instant reversing capability.
We have two very different campers (Granby, Bengal) with different vent brands/dimensions... and lifting of the front vent occurs on both. Opening and closing "polishes" the moving parts and so the friction "grip" eventually becomes too weak to hold the vent closed against the "air plane wing" vacuum. Everyone uses their vents differently and has a different starting friction and so "polishing" varies widely. We swapped handles between two vents and increased friction.
Our "cure": we fold stiff paper into a wedge or "T" shape("T" is better) and slip it between the handle and vent frame, snug but not too tight, wide end at the top. Removing and reinstalling the vent handle position in the closed spot to create the correct handle:frame space was required.
I suppose a piece of foam cut to the right shape would be another option to try.
I've used both maxair seems sturdier and more efficient as well drops right in same space hardest part is the caulk cleaning that off prior to putting in max air. My biggest mistake is picking a hot day to do the project and cooking out there in the process of the install. On the exterior part of the project I placed a dog blanket down and then plywood to displace the weight. Hoopy
I replaced my Fantastic fans front and rear with MaxAir fan units. On the MaxAir the hand crank you push up on it and that locks the hand crank from rotating. As far as I know the Fantastic lacks that feature thus allowing the crank to turn and vacuum (negative pressure) to open the lid.
Even with that handle locked, the air moving across mine still lifted and broke the mechanism. The air dam fixed that.
Interesting... must have had a constant vibration that allowed the MaxxAir knob to drop out of lock position.
If it is just a matter of disrupting the air flow across the top of the vent what about gluing a stiff or flexible piece of rubber to the leading edge of the vent top to kill the speed of the air across the vent top and therefore any negative pressure/left on the lid.
If air stream created vibration is an issue, then this might also help.
Lastly as mentioned by some, I have 1.5 inches of clearance above my Hawk getting into my shop; while I do not need the rubber air dam mentioned above, even if it did contact the top of the entrance frame it would bend and not break.
Hey, just a couple of thoughts and still have not seen photos of mechanisms described as weak links causing the vents to open, nor if this is predominately an issue on frame rather than truck bed mounted FWCs. How many FWCs has this actually happened to?
I don’t have pictures, but can describe. In the first episode, the teeth on the control arm were stripped by, apparently, the chattering motion against the gear. I replaced the control arm. On the second, the plastic tab connecting the control arm to the vent lid snapped. I replaced the vent lid. As noted, i switched from flat lid to domed lid and have not had an issue in 8000 miles. Perhaps the change in shape was enough?
Experiential knowledge is always best...flat lid = problem ; curved lid = no problem; issue solved...again I believe Dirt Road Savant's Hawk is on a frame mount....
