So, call me anal, but it seems like the lifting panels are important so I want to make sure I'm not messing anything up...
I fiddled with the wiring behind the front lifting panel to try and prevent shorting (before a more permanent fix -- my wires are broken behind the panel).
After packing up and lowering the front, I looked to see how much room there is in there for the folded up wires. It looks like the wires (at least the way I left them) are making the lifting panel bend a little bit. Is this normal, good, bad, or otherwise? It seems like the panel is going to flex at least a little with anything back there, but I did tape on some slightly larger split-loom - but not that much larger, and most of it is sticking out the side and is not between the panels.
The photo might show what I'm asking: are the panels "parting ways" some and does that matter?
Thank you as always.
