HappyCampers
Hey folks,
I've used the search function here, but haven't hit pay dirt unfortunately. We purchased a Dometic CFX3 fridge during a hard to resist sale last month at REI. This will be replacing the original ice box and, while not a 'perfect' fit, it will occupy the same cabinet space.
My plan all along has been to install a female 12v socket in the cabinet and I picked up a single port ARB threaded unit for this. What I hadn't given much thought to is the wiring. Upon removing the ice box, I discovered that 4WC pre-wired the cabinet for a fridge (along with propane stub out).
There are three wires and I'm unclear as to what these are and if I can take advantage of these. I'd sure like to avoid the bodily contortions involved with running separate wiring. There are two 12 gauge wires (blue and black) and a single 14 gauge wire (blue). Can someone with solid knowledge on this tell me what these are?
My follow up questions have to do with wire size and fusing for this fridge. Assuming the 12 gauge wires are 12v pos and neg, is this sufficient or do I need 10 gauge here? Secondly, I'm wondering about fusing needs. Since this is pre-wiring for a fridge, is it safe to assume this is already addressed?
Your patience and helpful expertise are appreciated!
Chris
Chris
