Front of camper structure
wanderingMT
May 12, 2024
4
Hi all. Newbie here.
Is there a resource for the location of structural members in a FWC Fleet Shell?
I want to mount something to the wall closest to the cab. It's pretty flimsy overall and I want to hit a stud or something else in order to mount the leg plate of a Lagun swing-out table. Thanks!
You can find pics of the structure but unfortunately FWC doesn't give out the exact dimensions.
Super helpful. Thanks!
I've tapped a lot of drywall looking for studs in houses, and those photos pretty much match up. When I get to that point of the build, I will post photos.
Here's a stud sensor that works well in my build. The pic is a mockup detecting an aluminum frame on a portable solar panel behind the standard paneling. Although the camera lens is off slightly, the center notch is directly over the metal edge when the third sensor lights up.
Hope this helps.
Hope this helps.
Good information, thanks for sharing.
Thanks for those stud finder photos, Archer Jim.
My stud finder was lighting up when I tried it in the camper but I couldn't make sense of what they were indicating.
I have some aluminum bar and scrap wood, so I can set up a test like yours. That should get me there.
Sorry for the delay posting. Life gets in the way. In the end, the most stable solution was 2x8 milled to about 1 3/8" and cut to fit between the side cabinets. Attached by a strap on the top as shown, and toe-screwed into the end from inside the cabinet with a rt angle adapter for my drill. Super solid, with no out/down flex. The black cord on the right is a bungee to hold a 5g water jug tight to the back wall.
