Timothy McGowen
RafterC
What are the three lowest grades in school?
HowdyTacoTruck said:Has anyone ever heard of FWC jack brackets failing under any condition?
Does fluid in a gas container provide a dampening effect on wash board road as opposed to a solid weight? Engineers?
I'm just a redneck fabricator, LOL.
Good to add more support points but determining the "somewhere else" keeps me from jigging up a fuel bracket...ntsqd said:My concern stems from the potential results of a mount failure. Not just the obvious possibility for fire, but also what such a failure could/would do the to the jack bracket's attachment to the camper.
Two bolts thru the jack bracket and one or two bolts somewhere else would be a LOT more robust solution than just a couple bolts thru the jack bracket.
Yeah, that IS the $64 question, isn't it? Looks like Craig has one good solution.Wallowa said:Good to add more support points but determining the "somewhere else" keeps me from jigging up a fuel bracket...
Phil
ntsqd said:Yeah, that IS the $64 question, isn't it? Looks like Craig has one good solution.
Haven't got it mounted yet, but I'll be using this shovel bracket on the back wall behind the door. They are available from Cascade Fire Equipment:doc said:Oh, and also contemplating ideas for mounting a shovel to the can? Has anyone done this?
Right now, I keep a shovel in the backseat, but for obvious reasons avoid using it. If it were outside, even to help put out a campfire at night would be less of a concern...
Those are the ones.... I spent 30 years at Marin County Fire. Got my first shovel bracket like that in 1986.craig333 said:We used something similar on the fire engines when I worked for CDF. I'd forgotten about those.
