Full build - Reconstructing a 1981 Grandby into a custom Hawk!
The turnbuckle access holes are inside the dinette seat boxes on the passenger side. It will be a tight place to work around, and I’m hoping works out okay. I’m not planning to take the camper off very often. In honesty, I didn’t have the opportunity to look over a factory built model in person before I did my floor pack in the beginning and cut the access holes, I just went off of pictures from the forum, and I’ve tried to complete the interior build with as much common sense as possible. I think it’s going to be a little difficult to access the turnbuckles, but I think it will work out. For sure there’s a lot of trial and error that has gone into what the factory puts out these days, and I’m sure many kinks have been worked out. Wish me luck on mine.
Storage spaces were made out of what seemed like available useable space, and not sure what will go in them fully as yet. Batteries will go in the lower half of the front seat box, Lagun table mount pieces will go in the narrow storage compartment along the side of the dinette when the bottom bunk is in use.
Hi PB
Ok I think I get it. I guess I should look up those lagun tables. I assumed you just left the brackets on the table. I will say that we move more than I would like round and round as we go from day to night inside. So you were probably wise to create a space. Have a tall young flexible person on standby to help.
Good weekend catching up some more on completing this project.
First let me catch up on some things I meant to include on the last post. On the rear seat box nearest the door, I had to insert and attach two aluminum Chanels, bolted to the side wall, to take the pressure exerted on the box when leaning back on the seat. I also created two brackets out of bed rail angle iron I had handy, to form the seat back supports. Here's a few shots of those.
full
full
full
Seems sometimes you have to back up a little when you find something not quite right. Had the camper off the truck for the first time since I loaded it over a year ago. And when off and I could see the underside, I noticed some slight weathering on the floor pack beneath the door where moisture catches the overhanging part of the bottom during in-climate weather. Even though I had applied a generous amount of marine enamel to the underside when building the floor pack and had the camper upside down, there was still some moisture penetration and slight cracking of the exterior of the plywood along the edge. Hard to believe, but once discovered it need to be addressed. I noticed this when I was adding some 1x4 runners underneath the camper, permanently attached, verses the 1x2 slats I had put in the pickup bed loose originally.
full
full
I applied some more paint but didn't feel the paint was going to seal up the cracks very well and they might worsen. Then I remembered what Bombsight had done to his underside floor pack, and decided I would apply truck bed liner as he did. I chose the same brand as Bombsight after reading some reviews. It's called Herculiner, and comes in a kit that includes a roller with two stiff foam roller pads, some scotch bright sanding pad, and a paint brush. The directions call for slight sanding on any glossy surfaces to scuff them up, and then applying a first light coat of the product. After allowing to dry for several hours (1-4), applying a second coat. It went on pretty much that straight forward. You have to wait until the first coat is no longer tacky to the touch, which took about 3-4 hours on a warm day for me. The formulation has small bits of rubber suspended in the solution, and it's a polyurethane base if I remember right. Plan on getting messy and throwing away a set of clothes. Theres no way to apply this stuff on the underside without it dripping down onto you while working. It doesn't come off of skin very well either, if you leave it too long. It was tedious to apply as I had to dob along all the edges of the 1x4 runners, as well as the various angles of the floor pack with the included paint brush, before using the roller to apply in between. But now it's done, I'm very pleased with the outcome.
The floor pack now has a plastic coating sealing up everything really well, and I hope keeping this pretty much maintenance free. Additionally, I now have the runners installed, and a more slide resistant surface as well. Heres a few shots of that.
full
full
full
full
While that was all drying, in-between I began working on sewing up the seat cushions, which Im happy to be tackling now. I had previously purchased a 32"x82" piece of cushion foam from Galaxy Upholstery Supply in Las Vegas. It's fairly easy to cut the foam utilizing an electric carving knife which I picked up for a few bucks at a thrift store. It works the knife pretty good, but it did the job. The cushion covers turned out pretty good. Cutting out the pieces and sewing them takes a little getting used to again when it's been a while. But I'm getting the hang of it again and they're getting easier.
full
full
Well I'm that much closer. The camper will go back onto the truck bed this coming weekend, and I'll permanently mount the seat boxes and the water tank
box, and then start preparing the water system for hookup. Stay tuned.....
Poky
Nice Pokey!
Very timely for me, I'm starting to work (FInally) on my dinette. Remember back a couple years ago, I went out to the camper to measure and make plans for a dinette only to discover the flood :( Ultimately, the dinette was put on hold. Way past thread update time now.
Last time I worked with bed frame iron that stuff was so hard I almost gave up on it. Wonder where that steel comes from? But, it is cheap, especially since it's often laying around the scrap pile!
Hi Wuck,
Thanks for adding the link back to your post. I do remember your project, and it was interesting to see how you tracked down the leak and solved the problem. I trust it’s still doing fine after all the work you put into it.
Make sure to post your side dinette build when you get it started. I’d love to see what you come up with!
Poky
Tim, Thanks for your comments. Ive still been enjoying your video postings too.
Well the surge continues. I've been busy over the last week or so with several projects as I near completion. In my last posting, I had begun sewing up the seat cushions, and now they are complete, for a total of eleven between the upper bunk, and the lower dinette/ bunk. I had purchased a large roll of fabric that I figured should have enough, and then some, to complete the arrangement. To my surprise, and delight, it ended up I had only just enough for the last cushion, and wouldn't have had enough for even one more. Good thing I didn't make any serious mess ups. So I truly lucked out. I used naugahyde on the bottom of the upper bunk main cushion, which in hind sight, spared me from running out.
Anyhow, it sure is nice to finally be to this point. I'm pleased with the way they turned out, all in all, and it gives the camper a finished look and feel. Here's a look at how they turned out.
full
full
full
The bed cushions in an up position if needed.
full
All the cushions laid out to make the lower bunk.
After having all the seat boxes of the dinette out to stain and finish them, I had to disassemble most of the wiring connecting the batteries and solar charge leads. Now the boxes are back in, I put in new wire to replace the temporary scraps I had used before. I added an inline fuse from the battery to the fuse panel, and new wires hooking up the charge controller. I also installed a master shut off switch, and shut off switches for the refer, and the USB charging station/ 12 volt outlet.
full
full
Finally, I installed the water system, including the water tank, the electric water pump and switch, and the sink and faucet. I still have to hook up the drain hose and valve to exterior, and that's underway.
full
full
full
That's it for this week. I'm getting ready to head out for a weeks vacation in the camper 4th of July week, so I'm really looking forward to that. Just a few things to finish up during the week, and then stocking up the camper with food, cooking utensils, and filling the refer with cold items. Should be loads of fun!
Poky
On the 4th of July holiday week, I was able to get away for most of the week for a little R&R. This was also my first trip after completing all the finishing of the dinette cabinetry, the new seat cushions, the water system, and the Lagun table set up. I must say it was very comfortable and also satisfying to have things caught up and functioning, as all the systems and appliances functioned perfectly. The solar panel and batteries kept up with demand draw from the 12 volt DC 130 L Isotherm fridge, the ceiling fans, lights, etc. My biggest concern was during the night. I use a CPAP, and I've never had it available until this trip because I didn't have a 12 volt outlet, and my sleep has always been affected as a result. This trip, I was able to run the CPAP at night, along with the fridge, and never ran too low on power, and most importantly, slept much better.
I visited Capitol Reef National Park in Utah, as well as some old familiar sports in Southern Utah. I boondocked for all the camp sights, so below are some photos from that trip.
full
full
Camp sight #1, which was at Forsythe Reservoir.
full
full
full
full
A few shots of Capitol Reef's geologic formations.
full
full
full
full
On the back side of the central part of Capital Reef's main attraction area, there is a dirt road that drops down to Bulfrog on Lake Powell, called the Notum Road. After about 30-40 miles of washboarded, bouncy roadway, and was only good for about 15mph, this leads you to the Burr Trail Road. You have to go up some switch backs, which aren't a problem for a truck and FWC, but would be a little challenging if pulling a trailer. Once up on top, after a few miles, the road is then paved and takes you over to Boulder Utah, and is part of the Grand Staircase-Escalante National Monument. It's some more beautiful back country, and is administer by BLM. Once in Boulder there is a small Anasazi Indian Museum, which is worth stopping for.
full
full
Additional camp sights
full
full
I also visited Cedar Breaks National Monument on Cedar Mountain, above Cedar City, Utah. (That's a lot of "Cedar" there. ;))
All in all, I had a grand time. Doing it again, I would take it slower, drive less, and do some hiking to see even more.
Poky
PokyBro
Thanks for sharing your trip wit us. Camper looks great glad you had fun. Yes sometimes better to travel less and see more.
Russ
PS good trip report.
Camper looks great Poky! Glad you had a nice trip. Been so hot here on the east coast my FWC hasn't moved. That's about to change. I modified a regular window A/C unit to go in my front slider. Can't use it while on the truck, but I always take my camper off at my destination. The wife and I will be heading to Lake Erie in NY for some walleye fishing the end of the month.
Just wanted to tell you how much I appreciated your thread and your help with my project. Without it, my project might have been gone to the scrapyard! This is a great forum and a godsend to those rehabbing old FWC.
Hello folks, it's been awhile since I've posted and thought I'd do a little catch up.
First, Just wanted to thank Shellback for his kind comment.
Well, I've done a few more projects on the Four Wheel Camper.
When I was installing the water system in the summer, I had to figure out a way to do the water tank drain. I realize some route the drain water line to the exterior along the floor pack to the rear of the camper.. I wanted it to go through the camper instead, and not wanting to have to see the water line along the floor, I built an elongated wood box/ tube for the water line to run through, at the base under my cabinets on the galley side. It does become exposed when it goes through the drawer cabinet before it exits to the exterior, but won't be seen once the drawers are in. I then went with the metal flange and ball valve on the exterior used by others in another post some time ago. The arrangement has worked out really well, and should be durable enough to last a long time. Nice to be able to just drain the water tank easily after an outing.
full
full
full
Next, I installed the 120 Volt AC line in from the exterior 30 Amp inlet, through a breaker box, and into two outlets. One on the galley cabinet for use of accessaries, and one under the cabinet to plug in the Iota DLS-30 W/ IQ4. This required a bit of wiring, and some cutting on the cabinet face frame. It all went pretty smoothly. I haven't used the converter/charger yet because the solar is keeping the batteries up, but now I'm prepared if the need arrises when storing out of sunlight, extended bad weather, or if I need to use shore power at a campground in shaded conditions.
full
full
full
Next I fashioned some corner covers for the seat boxes serving two purposes. One to hide the edge of plywood on the box, and two, to keep the wood from chipping on the edge if hit with shoes or objects with use. I also like the aesthetic look it added.
full
Lastly, I acquired a Four Wheel Campers sticker from Stan at FWC ( Thanks!), and officially christened the camper as a legit FWC just as it went through the factory doors originally way back in 1981, with a major remodel, nonetheless.
Oh, another thing...Recently I had the opportunity to weight my rig while taking some things to the landfill. I'm estimating my camper to weigh around 1300 lbs. without the batteries or a tank of water. Not bad all in all.
full
That catches me up on the building process over the last while. I've also had it out for several outings since I posted last, more to come!
Poky
On the second week of October, I went on my annual elk hunt in Colorado and Utah. There's a number of things to share about the outing.
The weather was variable with bright sun, to overcast and snowing. While I had experienced some troubles with the Atwood furnace, the repair I made earlier in the year, of replacing the sail switch, resolved the problem. Compared to the 12,000 BTU furnace I originally installed, the new 18,000 BTU Atwood worked much better. The noted difference was before on the first furnace, in extremely cold weather, it seemed to run constantly to keep up with the chill outside, utilizing considerable amount of propane. The new furnace cycles in much shorter periods of time, and with the digital thermostat, keeps the camper a nice even temperature and uses much less propane, just what I had hoped.
We did experience a considerable amount of condensation, but I expected this and didn't worry about it much. Didn't have an outside thermometer, but was pretty sure it got down to single digits a night or two. We shut the furnace off at night, and bundled up in two sleeping bags. Still froze water inside the camper in water bottles and even with two sleeping bags I got a little chilled. We used a five gallon water jug for water needs, as the water system has been winterized, and I didn't want the fittings to freeze and break causing leakage. The solar system, and the batteries kept up with power needs despite the overcast conditions. The main power draw was the DC Isotherm fridge, the furnace, lights, and a CPAP at night.
full
full
My hunting buddy was a friend from work, where we once were partners in a sales territory. We had a good time, getting up at 4:30 AM to have breakfast, load packs, bundle up and set out hiking up the mountain before first light. We saw a lot of animals on the first day, and my buddy was able to take a bull elk in the early afternoon. That meant the work began, because the meat had to be cared for. We hung some of it to cool, and then began packing some of it out. We were back in about two miles from the road, as this is a hike in or horse area only, which doesn't sound like much until you're carrying a 70-80 lb pack. The hips and shoulders really feel it by the time you get back to camp.
full
full
full
full
I was able to take a cow on the third day. We took a total of nine loads to get the two elk out and back to camp. As the snow was melting, the terrain was muddy and slippery, and careful footing was required, but I still went down twice. No injuries luckily. The scenery was beautiful, and we had the additional experience of seeing several coyotes, eagles, beaver, mule deer, hawks, and crows and Clark's Jays (camp robbers), to name a few.
full
full
full
The trip was wonderful and the Four Wheel Camper made the outing a delight. With two bunks, warm inside, a nice galley, with stovetop and fridge, it was way comfortable and delightful. I used to go in a white outfitters wall tent complete with a wood burning stove, camp stove, lantern, chainsaw, axe, etc. Really roughing it! That took a lot more equipment and time to set up and take down. While it was comfortable and fun to use the wall tent when I still had my sons at home, for just two people the camper is so much more simple to use and can't be beat.
There were no issues with leakage or anything malfunctioning, so it seems I've got things dialed in.
full
Poky
Congrats on the elk! Especially packing it out yourself, nothing about elk hunting is easy. Oh yeah, camper looks good too ;)
