FWC Battery care
Thanks Rando.
I'm looking closely at that NOCO Genius G3500 on Amazon.
Is that 3.5 amp the correct model for my Hawk and its two batteries?
Advmoto18 said:
If AGM batteries, good read here.
I do not keep my AGMs on a maintainer. On an as needed basis, I plug into shore power, monitor the battery state. I remove shore power once I have a full charge or when battery temp reaches 115F. I have a small, surface mounted thermometer on top of one of the batteries.
Yes that is a good read. Thanks!
Bombsight said:
Thanks, guys. Can we make this simple and just post some Amazon links as to what I need? :D
Vic ... I got that controller photo off the internet. Its not actually mine. Mine is just like it though.
Let's go back to the original posting. You said you leave it plugged into shore power. That might be enough.... if you have the FWC stock IOTA with IQ4 installed.
http://www.iotaengineering.com/dls30.htm
http://www.iotaengineering.com/iq.htm
Is your camper so equipped?
As I pointed out in my ponderings about all things FWC/ATC electrical,
http://www.wanderthewest.com/forum/topic/13230-i-need-more-power-scotty/?hl=%2Bmore+%2Bpower+%2Bscotty
the IQ4 is not ideal, but if you have one already, just keep plugging it in to shore power and fuggedaboutit.
Whatever brand battery maintainer we have, either a 'Minder or a 'Tender, it uses the SAE connectors like FWC uses for solar to swap between clamps or dedicated ring terminals. I mounted ours permanently next to the battery box and hard wired it such that the TriMetric 'sees' its output. Even bought the battery temperature sensor for the unit. Have not installed it as I have used the battery charger maybe 2 times since installing the solar. That said, I'm including a dedicated 120 VAC outlet for it in the IP complete re-wire project as pulling it's cord out and stretching it diagonally across the kitchen area to the lone 120 VAC outlet in the camper was not earning me any Brownie Points.
Thom, Let me know if you find a good affordable external AC power inlet.
Bombsight, In this pic you can see my NOCO 7200. The 3500 gives you 1/2 the current = 3.5 A. This is a very slow charge, fine for maintaining, but very slow if you are trying to take advantage of plugging in at a campground.
full
I use an old laptop battery charger plugged into my solar input when I don't feel like dragging my panels out to charge my portable setup. I also do not charge it all the time. If I am not using it I charge once a month, let it draw 3 or so amps (2 35 AH batts in parallel for 70 AH) for 4 or 5 hours or until it isn't really drawing anything.
I can't explain why I do it that way except I feel it works the batteries a bit more by letting them discharge a bit before charging them. There is not real draw but they naturally lose some Voltage....
They are usually at 12.6-12.8 when I charge them so no real stress on them. I just hate always keeping them topped off, I think it is good to let them "breathe" a little. Just my thoughts, YMMV :)
I cannot say if this prolongs anything as I only built this little system last year. Guess I'll know in a few years,,,lol
Here's a picture of the Noco terminals hard wired to the batteries...Sorry for the sideways pictures.
First winter with my camper and want to make sure the batteries stay healthy (2- 12V AMG). I live in the Mountain West where freezing temps exist throughout the winter. My camper will be off the truck and inside my garage, but the garage is not heated and temps get below freezing inside the garage (20's deg F typically). Thinking about two options:
1) Leave plugged into shore power inside garage with batteries being maintained from IOTA with IQ4.
2) Remove batteries from camper and bring into house so they do not experience freezing temps. Maintain with NOCO Genius G7200.
Thoughts?
P.S. - If Option 2, can I hook up batteries in parallel and maintain them both using one NOCO G7200? Or do I need to maintain them separately and swap the charger between the two ever week or so?
Thanks.
P.S. - If Option 2, can I hook up batteries in series and maintain them both using one NOCO G7200? Or do I need to maintain them separately and swap the charger between the two ever week or so?
Thanks.
If they could freeze I would go with option 2. However, you need to wire in Parallel to charge both at the same time. Series would give you 24v. + to + and - to - just be sure to hook the changer to the + on one batter and the - on the other battery.
Parallel, yep. Brain fart. Thanks.
