lmwilco1
I have a 2019 Granby Shell and want to add some cabinets and water to it. I need to cut a few holes through the side for the water fill and drain and I need to know where the aluminum tubes are. Is there a diagram available that shows the tube locations?
How is the interior paneling attached to the aluminum frame? I don't see many screws so I am thinking they may be using the same tape that the exterior panels use, trying to see if I can't get a diagram if I can remove the paneling.
Thanks,
Louis
Thanks,
Louis
