BobM
- Joined
- Nov 2, 2011
- Messages
- 730
Bob - a couple more questions. How did you attach the PVC fittings to the ABS? Looks like 3/4 PVC - did you just drill a 3/4 hole and insert the PVC fitting and glue, or did you actually tap/thread the ABS and use a male PVC fitting and glue. Also, where is your shut-off valve - is it the black or yellow piece near the outlet? Where can I get that?
Thanks
I just drilled the hole, no tapping. I also put electrician nuts on both side to help stabilize but it kind of self tapped. Again, I used a special ABS/glue. The shutoff valve is that chrome part right before the yellow thingy. Just a standard inline hose shut off. You can also get one of those yellow things with a shut off valve. They're just one of those attachments you use for filling the camper water tank. You can get them at camping world or any other camp supply places.
Thanks
