Hawk Cabinet Dimension
squeege4
Dec 22, 2020
1
Hello, I am new to the forum and looking for the dimensions of the various cabinets and bench/ledge areas of a Hawk Shell model with stove and heater. I can't seem to find anything on the FWC website or in these forums. Here is an image of what I am trying to describe. Your help and guidance is appreciated.
No idea if the "Shell" dimensions are different or not. I have a 2015 Side Dinette with most options. If you want a specific measurement just shout.. Sorry do not see image you mention.
full
full
still new to posting. Hopefully the two pictures post properly and provide you with some dimensions of the Hawk shell.
Last I looked the pic’s etc on the FWC site are old. The cabinets have changed (like that little niche at the back by the door is gone) I was kind of surprised when I picked mine up and had to rethink some of my plans. I do like the changes though. I think the basic dimensions are the same.
I will get some dimensions in a bit.
OK squeege4 the basics are mostly the same as above. I came up with:
77 1/2” across the back
Benches 16” W and 22”H
Passenger side bench 77 1/2” long
Driver side bench 52 5/8” long
Lower box (propane) 27” X 25”
Furnace 20 1/2”x 25”
Stove top 22 1/2”x 25 3/8 ( we don’t have the stove so the top opens to a storage but I would imagine the same size)
Here are some pics to help visualize. I hope
I added a piece of plywood to the top of the bench to make it wider and a piece across the back for a dog bed/lounger so that is what You see.
The notch is gone, but the dims in the pictures I posted are from FWC based on the newest Shell layout I even though the illustrations are older. These are for the bare Shell w/o propane. I plan on adding my own propane and a Truma Combi unit.
Here are interior pictures of the new Shell side cabinets. The drivers side shows Hawk with the Furnace option and solar.
full
full
JWL, you gave two dimensions on the propane box of 27” x 25”. I assume 25” is the depth of the box and 27” is the width facing the box. Can you please confirm and provide a height?
Thanks, Vic
25 would be the side you face and 27 would be the side off the bench. Hence that little shelf that sticks out.
That box is the same height as the benches. The furnace and battery box sits 20 1/2” on top of that.
