wuck
Bombsight said:Not to change the subject but to confirm ... can the 160 watt on the 2016 FWC's be used along with the 80 watt (fold up) panel on the back at the same time?
An MPPT controller will work fine with different solar panels in parallel connection, provided they are the same "nominal" voltage (eg 12, 24, or 36 volt). As the panels may have different max power points, there will be some loss of power. MPPT controllers always deal with this, think about a house with shading, dirt, bird poop etc. Every panel is slightly different. With different panel voltages, it'll still work, but the higher voltage panel will be dragged down to the low panel voltage, throwing away plenty of available power.Vic Harder said:YES, if you are using a PWM controller. NO if you are using a MPPT controller.
