Well, I've been lurking for a while and can finally call myself the owner of a FWC. It's an approximately 1988-1989 Grandby with stove, forced air heat, awning, and 3-way Dometic refer. Paid $1500 plus the cost of going to get it. Me being me I started tearing it apart to dial it in right away, thoroughly expecting to have to rebuild the cabinets to my liking when I bought it. I found some dry rot in the floor pack and the shelf the refer sits on which I'm in the process of patching -- I'll post pics of that later. What I have now is a BIG problem. I didn't really check the front end out very well and noticed while working on the camper it lacked "stability", so I pulled the screws off the front and folded up the skin a bit and discovered broken welds. D***! I then pulled (read ripped) the paneling off the inside front to get a better look. All the welds under the window are broken, as are two on the sides where it meets the step of the floor pack. All the other welds appear to be okay. I can't weld aluminum I'm afraid, so I'm looking for advice. I read one post where someone made up a bunch of aluminum L's and screwed them in. What about a combo of steel L's and T's either screwed or riveted to the frame pieces? I'm trying to get it back together in a couple weeks and would have had plenty of time until I hit this stumbling block. Any help is appreciated. Thanks.
