Hey all , i have a 2016 Raven. Bought it used in great condition. The man i bought it from said it had a mppt solar controller. any idea where this would be installed so i can see if it actually has it? I know there is a charger on the port side under my sink, this charges batteries when i am plugged into shore power... is it a standard option? mppt or does it come with pwm controller? I am also looking into solar panels, most likely a 200w to mount on my roof racks. Where can i get the correct male for the FWcamper roof solar female socket?
Thanks
Jeff
Edit
i think i found the connection i need from another thread.
https://www.amazon.com/Terminal-Wiring-Harness-Disconnect-Extension/dp/B07BKZ89TS/ref=sr_1_fkmr2_2?s=automotive&&ie=UTF8&&qid=1534253450&&sr=1-2-fkmr2&&keywords=sae+to+o+ring+12+gauge
this is the same connection that comes installed in the fwcamper roof?
Thanks
Jeff
Edit
