Hello,
I have a Norcold top-loading 45L refrigerator. It's powered by a factory installed FWC 165 watt solar panel, two 100 amp batteries, and the alternator from my truck.
When I drive the truck and have the alternator supplying additional power, the frig works normally.
When I turn the truck off, and use battery power alone, it won't hold the set temperature, and gradually gets warmer.
I have a trimetic meter, as well as the factory installed Zamp monitor. The trimetic shows the battery is 90-100% charged, yet the Norcold doesn't stay cold.
Do you have any trouble shooting suggestions?
Also, if I need to get it serviced, can you recommend a repair shop in Tampa or Orlando Florida for good service?
Thanks, John
Thanks, John
