Hodaka"Pops" Scout YOHO Camper Thread.
Hodakaguy
Oct 2, 2014
641
On to a new chapter and new adventures! We recently sold my fathers Revel as it hurt his neck and back to drive. We tried every combination of seat adjustments etc but just couldn't find a spot that worked. His Toyota on the other hand is comfortable for him to drive on long trips for hours on end so we decided to go back to a Camper that he can carry on the Tacoma.
We were looking for something more comfortable and warmer than the Drifter camper we previously had on his truck. We considered a Four Wheel Camper as we've had a few of those in the past but at 80 years old he has trouble lifting the top up and down on those. After looking at a lot of options we decided to search for a Scout YOHO camper.
The YOHO weighs in at 950 lbs so the Tacoma carries it well. No pop top means no setup and the foam sandwich construction makes for a very solid and well insulated unit. We set to searching and found a clean one owner unit up near Seattle so headed off to strike a deal.
Happy new owner! The truck has a two inch lift and the heavy Dakar springs installed in the rear. The setup sits nice and level wirh the camper installed. Here the tailgate is still installed for the trip home.
Some interior shots of the YOHO. The large side windows & upper skylight all open and have built in shades & bug screens. There is a Dometic compressor fridge, a two burner stove (which is huge so we will probably remove it and use a backpack stove instead to free up more counter space), a lithium batt bank, a sink with a 5 gallon pressurized water jug and a very cool marine stainless propane fireplace to keep you cozy at night.
On the Ferry heading back to Eastern WA.
You can see the solar on the roof from the front angle.
The weekend after purchasing the camper we set off to the Hood River OR Antique fly-in and my father got to try out the camper. It worked great!
While we were in Hood River I took the Hack down the road to DIY Van and snagged a Maxxfan 7500 that I will be installing in the YOHO. The tiny factory fan/vent that came installed in the camper is almost useless and is super noisy....the Maxxfan will be a great upgrade!
More mods to come.....
Hodakaguy.
That's nice looking rig. :) I'm surprised that the YOHO is short enough to fit entirely in the 6 foot cargo bed. This model would be a perfect fit for my 1st Gen Tundra should I ever step up to a hard side.
Yeah it fits the 6' bed perfectly.
Hodakaguy
First Mod is to replace the rear window on the door with one you can actually see out of. Not sure who thought it was a good idea to use a window made of bathroom glass in a camper lol.
We found a replacement window with a built in shade on Amazon for $89. With the window in hand it's time for the installation.
Supplies used:
Note: The links below are my Amazon Affiliate links, I make a small portion each time someone purchases from Amazon using one of my links, at no extra cost to the buyer. I only provide links to items that I personally like and use myself. i use the money to put back into my builds and support making videos/posts. If you prefer not to use my links you can search for the same items directly off Amazon. Thank you for the support!
AP Products Slim Shade Window: CLICK HERE
The OEM frosted window.
New unit.
To remove the original window take a screw driver and push inward at each of the locking tab locations on the inner window frame. The screw driver will break the tabs releasing the inner frame. Once all the tabs are snapped carefully pry away the inner frame from the door.
Inner frame removed.
Remove the glass from the window then pry off the outer frame.
Remove any remaining sealant left behind from the frame.
Getting ready to install the new window. The frame comes with the sealant pre-applied and ready to install.
Window shade installed. It's a little tricky to hold the shade in place while you place the unit in the door.
Using some tape to hold the outer frame and glass in place while I install the inside frame.
The inside frame on the new window attaches via screws.
Continued Below.....
Continued from above....
And done! Took about 30 minutes and now we have a usable window. Should have left the factory this way!
And it's not quite complete without an official Hodakaguy sticker lol.
Hodakaguy
Ventilation....or lack there of.
With the huge opening windows and a opening skylight as well you can get cross flow ventilation unmatched by most campers....but. When you close up the windows there is a serious lack of ventilation. The YOHO came with a small round powered vent fan that is super noisy and flows little air, it's basically worthless. Time to fix that! We planned on installing a Maxxfan 7500 from the time we purchased the camper. The 7500 flows a lot of air, it's super quiet, it's reverable, can be left open in the rain or while driving and has an automatic setting that will turn itself on/off based on the setpoint you program into the remote. I have the same fans in my van and love them!
Supplies used:
Maxxfan 7500: CLICK HERE
Sikaflex 221: CLICK HERE
Dicor Self Leveling Lap Sealant (2 tubes): CLICK HERE
Here you can see a couple things. One is the worthless small round vent fan on the left rear of the camper, the second is a bubble on the roof. The bubble is a delamination between the fiberglass/foam on the roof panel where the glue has failed, a defect from original construction. I noticed the De-lam when we were purchasing the camper but as luck would have it the De-lam is located right where I planned on installing the Maxxfan...perfect!
I'll be tapping into the LED light wiring to power the fan. Here I'm disassembling the light to gain access to the wiring.
Laying out the location to cut in the hole for the fan. The hole will remove about 95% of the De-lam.
Here I've taped a bag to the ceiling to catch debris while cutting the hole.
Here I've drilled a hole in each inside corner to get a start with the jigsaw.
I used a round file to round the inner corners of the hole, you don't want sharp edges as they cab cause cracks.
The remaining portion of the De-lamination is visible now.
I couldn't have picked a better cut line, the edge of the hole exposed the wiring for the light and didn't even knick it! Sweet!
Here I'm making a pencil line where the fan base flange will set so I can sand/prep this area for install.
Time to fix the De-lamination. I'll be gluing the De-lam back down with Loctite EA E-30CL structural epoxy.
Continued Below....
Here I'm Injecting the epoxy into the void then clamping it down solid to cure for 24hrs.
24 hrs later and the roof is like new again.
Screw holes for the fan base drilled.
Lightly sanding the mounting surface.
I'm using Sikaflex 221 adhesive/Sealant to seal the fan base to the roof. 221 stays elastic and holds up extremely well to vibrations etc.
Here I'm filling a syringe with some 221 to apply around the edge of the fan base.
Red Caps are great for re-sealing open caulking tubes.
Continued below.....
Marking the inner trim ring depth so it can be cut to size.
Wiring spliced in.
Trim ring installed.
Several days after installing the fan base I'm applying Dicor lap sealant as another layer of added protection and to keep UV off the Sikaflex 221.
And inside.
Last step was to mount the remote. I used 3M safe release adhesive strips to mount the remote holder to the wall near the bed, easy reach if you want to change the fan in the middle of the night.
Hodakaguy
Fridge clearance.
The door on the fridge hits the window frame when you open it, so you end up having to slide the fridge over away from the wall. But the next time you go to use it the fridge has worked its way back against the wall again and you have to slide it back once more. Time for a fix.
Fridge removed to gain access to the wall.
I'll be installing these rubber bumpers on the wall to rest up against the fridge and push the fridge out a bit.
A bit of Sikaflex 221 will keep the bumpers in place and reinforce the screw in the fiberglass wall panel.
I measured the fridge and installed the bumpers where they would not come in contact with the air vents on the fridge.
At this point I test fit the fridge and it was just on the edge of clearing...a bit more clearance would he nice. To gain the extra bit of clearance I applied adhesive felt pads to the side of the fridge at the locations where the rubber bumpers will rest. Perfect, about a 1/4" of clearance now between the fridge lid and the window frame...and the fridge is locked in rock solid!
Hodakaguy
Great report as usual. The pictures do say a thousand words. Cutting the hole exposing the wires without cutting them proves. Sometimes it is better to be lucky than good, but you got both with that hole. I did notice the cordless caulk gun, I bought one when I did a re-caulk on my van roof. My 73 year old hands loved that caulk gun.
Thanks Mate! The electric caulking gun is really nice and much easier to get smooth consistant beads. Love it.
Hodakaguy
Project Overkill! - Stronger tie down points.
We have our YOHO on a 2012 Tacoma which uses the plastic/composite bed. The OEM tie downs just don't give us a warm fuzzy feeling as they are small and only attach into the plastic/fiberglass itself. When tightening down the straps you can see the tie down points flex with the bed....time for a fix.
I decided to make some tie down units that will be stronger than anything we will ever bolt to them. My tie down brackets utilize the lower OEM bolt that secures the bed to the truck, the bolts go through the bracket and directly into the frame. Then I added two more bolts that go through the side of the bed like the OEM tie downs except with larger bolts and a lot larger backing plates. My father tig welded the shackles onto the brackets and they were ready for paint.
We utilized material we already had around the shop, which turned out to be 3/8" steel (larger than needed) but we already had it so Bob's your uncle!
OEM tie down point. This just won't do.
4" wide by 3/8" thick flat bar. Overkill but it's what I have on hand so it will do!
Pieces cut to size.
Here I'm getting ready to bend the flat bar into shape and wanted to make a quick gauge for the bend. I removed the bolt holding the bed onto the frame and bent a piece of tig rod into shape.
Laying out the bend points.
I planned on heating the strap with a torch and making the bend in my vice buy my Oxegen regulator failed right as I was starting....dang! Well I have access to a large press so I packed up and headed across town to bend them on the press.
Starting the bend.
Checking the bend...nope more to go still so back in the press.
One done....and two done.
Test fitting.....fits perfect.
Drilling holes.
Continued Below....
Making sure I got the hole drilled in the correct location. Yep, still fits perfectly.
Rounding the corners. Once marked I use the Portaband to remove most of the material, then over to the sander to give it the final touch and clean it up.
One side assembled and ready to weld.
My dad working his magic with the tig torch.
All welded out.
Final test fit.
Fabricating the backing plates out of 1/8" steel.
Backing plates drilled and test fit. Ready for paint and final install.
Continued below....
Drilling the holes in the bed for the side mounting bolts.
Here using a reemer to clean up the inside and outside edges of the holes.
Applying Anti-sieze to the stainless bolts that will go through the sides of the mounts.
Mounts installed and bolted in place. You can see the size difference between my backing plate and the OEM tie down backing plate.
Custom front mounts installed and ready for use!
This setup is exponentially stronger than the straps that the camper will be held down with......Project Overkill Complete!
Next up I'll be installing bed braces on the rear of the bed that will also double as camper mounts. Stay tuned.
Hodakaguy
nice work tom !
i was looking at that interior water container on back wall - seems like quite a bit of weight back up there ?? i am sure you guys know better than i.
go
That is a nice looking camper and your work continues to impress. Great job and thanks for sharing with us.
TacomaAustin said:
That is a nice chassis mount. The upward L with a backing plate is nice touch - which should eliminate any tendency to wiggle.
Thanks Mate. :)
Hodakaguy
goinoregon said:
nice work tom !
go
Thanks, I'm pretty happy with how they turned out. Yeah the water location isn't my favorite either....not a great spot for Weight up high.
Hodakaguy
