dennis 221
- Joined
- Oct 11, 2019
- Messages
- 407
so when you sanitize your water tank an draining it , can you run the water pump to shorten draining processes??? if so how long is it safe to run pump !?? thanks
+1billharr said:I have drained my tank using the pump. Does not take long and I have checked the pump motor and it did not get hot.
I've done that a few times. Don't park though. Somebody will panic and be sure to let you know your valve is open or they may even close it on you.Norsman said:To drain the tank I just open the plastic valve on the back and drive home.
