This may sound like a silly question...probably because it is a silly question, but so be it.
The water pump in my 2005 Hawk stopped pumping a long time ago -- at least 3 years ago, I think -- and I removed it to troubleshoot it or replace it, neither of which I did (so I haven't used water from the camper faucet in years). But now I have a replacement pump.
My question/problem: I see and remember, more-or-less, where the pump was mounted -- there's still a big opening in the cabinet-panels where I removed it, at the front of the camper, just portside of the water tank, under the cabinets.
But I don't remember and can't figure out exactly where/how it was mounted.
I don't see any screw holes from the old pump's mounting!
Maybe the pump was screwed down on some intermediate panel (now removed?) and so that's why I see no residual screw holes?
Can anyone -- maybe someone who has worked on or at least looked at their pump -- clue me in on how it's mounted in their similar rig? Maybe there are photos here on WTW showing this -- which I haven't yet found...?
Now, I can see how I could mount it, there's room...but in the place I'm looking I don't see how the semi-rigid plastic inlet tubing from the tank (which I never removed) could possibly fit to that likely pump mount spot. I'm replacing the semi-rigid tubing with flexible hose that SHURflo sells, so I can make it work.
I'm just a bit perplexed on how -- exactly where -- it's supposed to be mounted. And I'm leaving on a big trip in 3 days...
Thanks for any help, guys.
