Input on Possible Solar Setup for FWC Raven
portermoab
Dec 3, 2019
25
Moab, UT
Looking to add solar to my 2019 FWC Raven, as the last cold trip resulted in a depleted battery due to (I think) a lot of use of the furnace. Camper has wired plugs but was not setup with any other solar. Currently have the standard AGM battery. I run the fridge on propane, so only need to cover battery drain from the fridge fan, interior lights, water pump, USB charging, and the furnace. I live in the desert SW, so there's typically a lot of sun, although winter is always a crap shoot.
After doing some research, I'm thinking of the list below.
- Renogy 100W Eclipse suitcase panel w/out controller (5.68A)
- Victron Smart Solar 100/15 Controller (Up to 290W/15A)
- Victron SmartShunt Battery Monitor
- 30ft. 10 gauge cable
Any feedback on this setup would be greatly appreciated. I believe this would leave the ability to add up to another 190W/9.32A in the future if needed. Does this seem sufficient to keep my battery charged based on my use? What am I missing, if anything?
Many thanks!
Great starter system. Why suitcase/portable? So you can park in the shade? If so, that makes sense. Way less hassle to have it mounted up top though.
I'd be tempted to go bigger on the solar panels. Rule of thumb for solar capacity = solar watts = Battery Capacity in AH x 2 ... so 85AH 2x = 170W
Thanks Vic. My thinking was that the suitcase made more sense as I'm generally camping in the desert SW and finding shade is a high priority. Although the reality may be more that I generally end up camping with full sun.
One approach would be to give it a try with the 100W suitcase and, if that's not enough, add a panel to the roof. Was keeping the suitcase at 100W due to size (folds down to about 20"x20" for easy storage behind the rollover couch). That said, it seems like a roof panel plus a 100W suitcase may be overkill based on your calculation (79AH x2= 158w), so I may save money starting with 150 or 160w on the roof.
Do you think 200w on the roof would be overkill? Or would I be better off keeping the roof at 150w or so and then add a 50-100w portable later if needed?
Many thanks!
200w on the roof is not unreasonable for a year around usage .Remember that solar on the roof you get input all the time the sun is shinning, even while driving around, parked in a parking lot anywhere, etc... Where as a portable you have to make a commitment to decide when and where to deploy and babysit it. Roof mount you get more solar hours in the day advantage and it is one less thing to do or worry about when you should be camping and enjoying the day.
Thanks. Re-configuring my ideas a bit based on this feedback.
- Victron Smart Controller 100/20 (290w @ 12v) (for some reason I listed the 100/15 above as 290w, when it's actually 200w)
- Renology 175W roof-mounted solid panel
This leaves me the ability to add another 100w of solar (technically 115w) either on the roof or a suitcase at a later date (if I end up adding a second battery or just need more solar).
Thoughts?
Hi portermoab
We originally had 150 watts on the roof with two 79Ah batteries. With overcast winter camping or shade, we did loose ground. Also we are running a compressor refrigerator, and all the other items you mentioned.
Adding another 100 watt panel seemed to have fixed the problem.
Russ
Thoughts?
I have 330w panel on the roof, 200AH of LiFePo4 batteries. If you are going to get a solid panel for the roof, go as big as you can since they all weigh more of less the same. If I was doing it now, I'd look at a 500w panel!
If you have the space and funds, get the 100/30 controller. I have had to keep getting new MPPT controllers as I up my solar array!
Vic, et al,
Using Renogy solar panels as an example I calculated that in all cases a single panel of the desired max wattage is lighter and less cost than using 2 panels once the mounting hardware is factored in.
Renogy does not make panels larger than 320 W as far as I can tell so I don't know how weight , weight per W and cost for larger panels compare.
See attached excel spreadsheet pdf
  • Renogy Panel W per pound Cals.pdf
Thanks again Vic. I hear you on going big, but I'm fairly limited on roof space. I switched my thinking from the one 175w panel due to size, and think I'll go with two 100w compact panels. The 100/20 will give me an additional 90w to work with later, and if I were to add another battery 290w would get me fairly close to the needed power based on the previous calculation (79AH x 4= 316w). So, now looking at the following, which doesn't seem bad at approx. $500 including mounting brackets and connector cables.
- Victron SmartShunt battery monitor
- (2x) HQST 100w "Compact Design" roof-mount solid panels
ckent323 said:
Vic, et al,
I love how you think!!
portermoab,
Take a look at the file I posted above. You will save weight and dollars if you just go with a single 200W or a single 300W or 320W panel.
Regards,
Craig
ckent323 said:
portermoab,
Regards,
Craig
I am not disagreeing with the analysis - but most of us with roof vents (including the OP) can't fit a 300 or 320W panel on the roof, thus one or more smaller panels.
The spreadsheet lists the dimensions of all the Renogy panels.
I note that the largest panel is 39.5" x 66". I have two fantastic fan vents on the roof of our FWC Keystone camper and even the largest panel would comfortably fit with its length sideways (width of the camper) between the two vents. or between the front of the camper and the front vent (the distance from the front edge to the front vent is greater than the back vent to the back edge on the roof of our camper but certainly the 200W panel would fit in the back.
Admittedly our FWC Keystone is a bit longer than all other available FWC models. I have seen the following measurements for a 2012 Hawk with two roof vents:
27.5" vent lid to vent lid
39" vent lid to rear camper edge
27" vent lid to front camper edge.
https://www.wanderthewest.com/forum/topic/14858-fleet-roof-measurements-for-solar-panel-install/
Clearly the 175W or 200W panel will fit between the vents on that Hawk and even the largest panels might barely fit between the rear edge and the rear vent (assuming the measurements are correct).
However, I do not know how much the vent placement varies with interior configuration (i.e dinette, rollover couch etc) or even build to build of the same configuration so it would be wise to measure carefully first! My guess is that the back vent placement varies more than the front depending on "kitchen" layout, but I am not actually sure of that..
The Grandby is a bit larger than the Hawk so my guess is that it is likely a 200W Renogy panel would fit between the two roof vents and maybe even the 300W or 320W panels. If not there, then I am pretty sure there would be room for any of the panels either in front of the front vent or behind the back vent based on the Hawk measurements.
I agree that the smaller FWC models may not have enough roof area for large solar panels, particularly if they have two roof vents.
Edit: Looking back at the initial post I see the camper is a Raven model. I don't know if it has one or two vents and what the vent spacing are. I checked the FWC website and I see no dimensional information for roof vent locations.
I hope this info is helpful to folks.
Craig
For the brain trust, a Raven roof with two vents measures out at 26" from front vent to front of camper, 28" between vents, and 32" from rear vent to rear of camper.
If some folks will send measurements for other campers with two vents I will add the measurements to my spreadsheet and post it.
So far I have measurements for a Raven, a 2012 Hawk and a 2007 Keystone. The Keystone has a rollover couch. I do not know about the interior layout of the Raven and Hawk and how interior layout may or may not influence vent location.
Edit: I looked at dimensions for LG, Panasonic, Sun Power and REC Solar 360/370 watt panels (all residential type). While the number of cells vary they are all between 40 and 43 pounds and about 66.5" to 68" long x 40" to 41" wide x 1.5" thick.
I will add this info to the spreadsheet along with camper dimensional info after some is posted.
Portermoab,
Looks to me like you can get a 175 W or 200 W Renogy panel between the vents. Maybe other panel manufacturers have 200 W or 300 W panels with different widths and weights. I don't know.
Here is an updated version (second page has camper dimensional info):
  • Renogy Solar Panel Comparison.pdf
Craig,
Couple of points...if, like us, you purchased a Zamp 160w panel that was mounted between the vents on a Hawk, then a second panel is the only option to adding watts [only 37 inches between vents] without discarding a functional panel.
The cost of a new panel Zamp 170w panel with hardware was $426; I am currently mounting that panel to the rear of my back vent.
Lastly, the 170w weighs about 24 lbs and your 320w panel weighs about 40.8 lbs....so yes, with our two panels the weight is more than a single panel by about 6 pounds. 48lbs for 330w vs 42lbs for 320w.
The weight however is distributed more evenly with the two panels...perhaps this is irrelevant in raising or lower the top... by adding the rear panel I am going from 30lb struts to 40lb rear struts...
Oh, my new back Zamp 170w panel can be tilted up to 45 degrees; not sure when this will really help, but it is another arrow in the quiver.
Phil
In regard to keeping it light, I found this 100w "compact" panel by HQST that they say weighs in at 9.92 lbs. It's also only 80 bucks. https://hqsolarpower.com/100-watt-12-volt-monoscrystalline-solar-panel-compact-design/
What's interesting is that a lot of folks say that HQST are virtually identical to the Renogy panels (they show the same specs and even ship from what appears to be the same location), but the "same" panel on Renogy's website shows it at 14.3 lbs (https://www.renogy.com/100-watt-12-volt-monocrystalline-solar-panel-compact-design/).
They look identical, so it's hard to know why Renogy would indicate more than 4 pounds heavier.
Wallowa,
Did you factor in the additional weight for mounts and cables that go along with adding a second panel? I think the weight of the Zamp panel is about 24 pounds but mounting hardware and a second set of cables for it plus Y adapters to use two panels will add to that and increase the total weight so my guess is the weight difference is going to be more than 6 pounds.
I presently have two 100 Watt panels and with cables and mounts they are close to 40 pounds total weight. They are right at the minimum we need for the way we use the camper so I want to add another 100 W or so. I am going to replace them with one panel. I will use those 100 W panels on my cargo trailer to keep the battery for the winch and the electric brakes topped up plus I will have extra power for lights and maybe other goodies.
I am presently looking at 360/370 watt LG, Panasonic, Sun Power and REC panels which can be purchased for under $300. Not sure what trouble is encountered trying to use a residential type panel. Heck there are single residential type panels up to 400 W and I saw an announcement for a 500 W panel. (based on our usage I think 360 W will be more than enough). My guess is the residential panels probably don't come with a pigtail having MC-4 connectors so those would have to be added.
If not one of the 360 W residential panels then a 300W or 320 RV panel (Renogy or equivalent).
Craig
Craig, my 330w panel is a "residential" panel. It came with MC4 connectors. My next panel will be 500W or more.
The only technical consideration is having a big enough MPPT controller to handle the input.
