OK folks, I got my batteries and want to start figuring out how to arrange stuff on the inside. So I need to disassemble the basic shell. How?
I figure the upper side walls are just scewed on.
The lower walls by the turnbuckle hatches appear to be double thick, and I need to change how the forward most hatch works, as it interferes with the water tank fill and vent lines. So, that extra layer of plywood with the wallpaper style wood "veneer" needs to come off.
How? I don't see any screws holding it on. This is a 2005 Hawk. I do hope it isn't glued together!
This opening needs to move
Plywood is single thickness above the wheelwells
Double thick down below.
