cfike
I noticed that the roughly 1"x4" piece of plywood that runs along the bottom under the rear door of my 2010 Fleet was starting to delaminate. I decided to replace the board and when I tore it off I found that it was water damaged.
Water seemed to be coming from the driver’s side rear corner and when I removed some of the siding in this area it was damp behind it.
The water might be originating in the area where the camper widens above the truck bed. Has anyone else ever had this problem? I want to find the problem but I don’t want to pry any more siding loose than I have to, especially since that seems like it might require removing a jack bracket and propane storage door. The camper has just been sitting outside, I haven’t exposed it to any road-driven moisture lately.
